Fujitsu Lifebook T936 specs
Discussion in 'Fujitsu' started by ATIVQ, Nov 15, 2015.
  1. ATIVQ
    ATIVQ V⅁O⅄ Senior Member
    1,048
    591
    Specs for the Lifebook T936 from the Czech Fujitsu site.
    • 6th gen Core i5/i7
    • 4/8/16 GB RAM
    • FHD/WQHD display, mirror finish, Wacom EMR digitizer
    • 128/256/512 GB SSD
    • Intel WiFi ac
    • Sierra Wireless UMTS/LTE
    • 45Wh battery
    • Fingerprint reader, smartcard reader, port replicator, backlit keyboard, TPM, vPro, dual mic, FHD front camera, Ethernet port
    • 1.6 kg (3.5 lb)
    No surprises, it's the T904/T935 with a 6th gen processor and 16GB of RAM. If it ain't broken, don't fix it.
    I hope they finally fixed the underperforming tinny speakers.
  2. sartonnis
    sartonnis Pen Pal - Newbie
    Glad they're sticking with EMR, at least. Lotta companies moving over to AES, for better or for worse.
  3. kvoram
    880
    785
    Nice find!
    Would have been nice if they had used the Core i7-6650U (Iris 540 graphics) instead of the Core i7-6600U (HD 520 graphics). RAM is probably still single-channel as well.
    Will be interesting to see how thermal and fan management works out. IMHO the achilles heel of many Fujitsus.
    If they didn't fix those poor excuse of so-called speakers, someone needs to slap the responsible persons over their heads.
    Also, given that their focus is mostly towards business users, I wish they would release something with a non-16:9 screen.
    ATIVQ likes this.
  4. stormi
    518
    318
    Most probably not. :rolleyes:
  5. LROBBINS
    LROBBINS Scribbler - Standard Member
    143
    34
    The speakers are the same awful on our two T5010, so this seems to be a Fujitsu choice and I wouldn't expect any change either. Making sure that you can't disturb an office environment?
  6. Rondo60
    Rondo60 Pen Pal - Newbie
    45
    Worth noting that the T936 will have Up to Core i7 Skylake CPU- Microsoft recently announced it an early support cutoff date for Windows 7 for Skylake processors, meaning you will be forced to use Windows 10. My issue presently with Windows 10 is the forced Windows Updates that at this time can replace some of your existing Fujistu drivers with Microsoft's default ones, meaning you may have to constantly keep re- installing the Fujistu drivers. So, I decided on the T935 with Windows 7 to be safe.
  7. in4mer
    277
    I'm in a remote area so bandwidth is limited and I need to prevent windows from updating automatically. You can turn off automatic updates through the administrative group policies.
    http://www.howtogeek.com/224471/how-to-prevent-windows-10-from-automatically-downloading-updates/
    Rondo60 likes this.
  8. Rondo60
    45
  9. Tams
    Tams Scribbler - Standard Member Senior Member
    864
    633
    Well, at least it's still EMR. With Fujitsu potentially letting it's computer division go, then it makes sense that there's nothing really new.
    Rondo60 likes this.
  10. kruzilla
    kruzilla Scribbler - Standard Member
    245
    34
    Looks like it's finally available. As usual, pretty expensive.
