Frequent keyboard disconnects after upgrading keyboard firmware Vaio Z Canvas
Discussion in 'VAIO / Sony' started by garagebattle, May 26, 2016.
  1. garagebattle
    garagebattle Pen Pal - Newbie
    18
    Didnt have much of a problem with the keyboard till i upgraded the kb firmware (hoping it would increase the battery life of the KB) but now Im getting disconnects 4-5 times a day where I have to switch the keyboard on and off.
    Cant downgrade the firmware, cant re-write the current firmware. Vaio support has been of zero help. Even occurred when the keyboard was plugged into USB.
    Went through the troubleshooting steps for changing the wifi settings but it did not help. Thoughts?
  2. Steve S
    7,879
    3,380
    <<...Didnt have much of a problem with the keyboard till i upgraded the kb firmware...>>
    On the other hand, I had a failure the first time I tried to update my keyboard firmware. Fortunately, the second try was successful. Do you remember if you got a "success" message at the end of the installation?
    If you don't know or don't remember, have you tried installing the firmware again?
    <<...Even occurred when the keyboard was plugged into USB...>>
    The USB connection does not provide connectivity for typing. Early on, I tried the same thing...
    <<...Went through the troubleshooting steps for changing the wifi settings but it did not help...>>
    In the early literature, there was a single sentence that stated that the keyboard used a "proprietary radio link" for higher reliability. It did not say that it was Bluetooth, so that may explain why you saw no changes. I have suspected for some time that whatever this proprietary link is, it is somehow indirectly connected with the Bluetooth radio, but I can't prove it.
    That's about all that I can tell you...
  3. hilokilo
    hilokilo Pen Pal - Newbie
    Jesus. I thought I was the only one. I had zero connectivity issues until I decided to update the keyboard driver. I tried to look for original drivers but I found nothing so far. Any help would be greatly appreciated.
  4. garagebattle
    18
    edit - had first drop out of the day.
    doesnt seem to be as bad as before, but still annoying.
    would really like to be have the ability to downgrade the firmware.
  5. garagebattle
    18
    Still doing it. Its done it 3 times today over the course of 10 hours. Sitting right next to the device, no wifi device nearby. Calling Vaio again.
  6. Mr. Boosh
    Mr. Boosh Scribbler - Standard Member Senior Member
    849
    303
    I've had the opposite experience so far. Keyboard disconnects are less for me with the new firmware. Haven't had one in awhile now.
    Unless there's an even never one released in the past month. Which in that case I won't update.
  7. garagebattle
    18
    With the trackpad turned off, I believe I am no longer getting keyboard disconnects.
    Also Japanese Vaio support is actually useful. They sent me a downgrade firmware (that Ive yet to try).
    Need to do more testing, will report back.
  8. hilokilo
    Can you send me the downgrade firmware as well? I'm desperate for a downgrade.
  9. garagebattle
    18
    hilokilo likes this.
  10. hilokilo
    Thanks a lot for coming back to me. It did install, and now I probably need time to see if it stops disconnecting. How is it working for you so far?
Similar Threads - Frequent keyboard disconnects
  1. Joseph S
    317
  2. siddhartth
    1,632
  3. WillAdams
    648
