For movies at the gym?
Discussion in 'What Tablet PC Should I Buy?' started by Richard Davis, Oct 5, 2014.
  1. Richard Davis
    Richard Davis Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    $200
    yes
    as opposed to what?
    5 to7-inches
    7.1 to 10-inches
    10 to 13-inches
    Above 13-inches
    Need help with that.
    US
    No
    For use at the gym:
    stream movies
    listen to music
    bluetooth headphones
    log workout (would like to write in a spreadsheet or something)
    protective case for shock if dropped
    protective screen if water drips on front
    glare protector for overhead lights
    no
    Netflix
    Amazon prime
    pandora
    Excel or equivalent OR a gym logging app
    words with friends
    yes but not a requirement
    Screen Specifics
    very high
    yes outdoors, near windows, under glaring lights
    dunno.
    I think I need a pen to write, but maybe a gym app would let me swipe checkmarks.
    Component Specifics
    Enoug for a couple of movies I think?
    I don't know
    Misc
    Most is in item 8, to clarify, I wear a bandana with ice in it around my forehead. It tends to drip all over my gym log. Very annoying. If I drip onto the tablet I'd like it to be impervious to that kind of thing. It won't be dunked or anything like that.
    It'll be on the recumbant bike. Would LOVE to have an articulated arm or something to watch while I'm lying on my back stretching. Someone invent that !!
  2. jb82
    jb82 Scribbler - Standard Member
    148
    27
    Waterproof tablets in your price range are limited. May be a Sony Z off ebay or a Sony Z ultra if you want something smaller.
    Could also buy a waterproof, shockproof case and that would open you up to pretty much any tablet. Probably most android tablets like the kindle fire have suitable cases that will suit your needs. There is probably an articulated arm accessory out there if you swing for an ipad.
  3. Richard Davis
    Decided waterproof was too high a bar. Considering 2014 Kindle Fire HD 7 with good case and glare screen. The articulated arm thing is out there but a little unwieldy.
