Fluid Math - Handwritten Math Solver
Discussion in 'Software' started by Steve S, Jun 22, 2016.
  1. Steve S
    7,633
    3,129
    DRTigerlilly, Bronsky and WillAdams like this.
  2. Steve S
    7,633
    3,129
    I just discovered that FluidMath has a compatibility problem with the Windows 10 May 2019 Update. When you try to open FM after the update, it will start normally, showing the license data and then opening the workspace window, but about two seconds later, the app will spontaneously close! I'm running FM on two devices (HP ZBook X2 and VAIO Z Canvas) and the behavior is the same on both.
    I've contacted FluiditySoftware to alert them to the problem, but other users should also chime in to be sure that this gets fixed...
