Flash Player Crashing IE9 on My Slate...
Discussion in 'HP Slate' started by ghost74, Oct 17, 2011.
  1. ghost74
    ghost74 Scribbler - Standard Member
    205
    From my previous attempt at using thadwald's driver I had the installation files already extracted in a folder. So in the control panel under device manager I right clicked on the display adapter and chose update driver. I then manually pointed the system to the .inf file. (have disk method)
    I then downloaded the crystal HD driver from the Slate500 support site and ran the install selecting the repair option.
  2. thadwald
    thadwald Scribbler - Standard Member
    264
    If you don't mind not running the latest version of flash, there is a solution. Apparently flash worked until it one of the updates broke it. I posted this problem on the intel forum and someone provided a solution. Follow the link for instructions.
    EMGD version 1.8 and Flash: Embedded Community
  3. ghost74
    205
    For the record I have 11.1.102.55 installed. I have not found a flash video yet that does not work. How did I get so lucky?
    Post any links to flash videos you would like me to test.
    It's there any information I can post or send to help debug?
  4. Bronsky
    8,084
    4,943
    Ghost74 - Your solution doesn't work for me. I loaded the driver exactly as you say, used the repair function of the broadcomm loader and still have the crashing problem. I'm back to the Intel 500 driver.:( I really liked the modded 600 driver but need flash. Hopefully, some genius figures out a solution to this as well.
    The modded Intel HD 600 driver installs as 8.14.181.2048 right? I might give that older version of flash thinggy a try. How would I stop it from trying to update all the time? Can that be toggled off? Otherwise it would be a real PITA.
  5. ghost74
    205
    Correct.
    I believe you can checkmark a box to ignore updates.
  6. ghost74
    205
    Flash quit working again...crap!
    Samething happpened last time, worked fine for a few days then it didn't.
  7. ghost74
    205
    Tried the older version of flash...no dice.
    IE9 just displayed aa black screen and forced you to update to the latest flash.
  8. thadwald
    264
    The flash update utility provides the option of ignoring the update in the future.
