Firewire in tx1200 series?
Discussion in 'Hewlett Packard' started by makryger, Aug 23, 2007.
  1. makryger
    makryger Pen Pal - Newbie
    34
    I was just looking at Best Buy's website, and it says the tx1215nr has a firewire port. Can anyone confirm this? Could this be the difference between the tx1000 and tx1200 series?
  2. topboxman
    topboxman Pen Pal - Newbie
    Nowhere at HP web site says firewire port is available for tx1000z series laptops. You will need to go to Best Buy and see it in person. If there is no Best Buy in your area, I can go there and check it out. Our store has it on display but I didn't check for firewire port. My tx1120us does not have firwire port.
    Check HP web site: http://h10025.www1.hp.com/ewfrf/wc/...2700&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
    Peter
  3. topboxman
    Went to Best Buy and found a display model and it was labeled as tx1215nr on the notebook. I could not find firewire port. Looks like Best Buy web site made a typo.
    Peter
  4. Speed
    Speed Programmer + Tablet Lover
    112
    I think there was a mistake on an HP site or manual some time back and some guys here chased HP about it and they corrected it. I think it was to do with a firewire port...
    I dunno where they'd put a Firewire port, anyway!
  5. stealthy1
    stealthy1 Pen Pal - Newbie
    There isn't a Firewire port anywhere on the tx series. Honestly, there really isn't any room to put a firewire card either, since the inside is pretty cramped already (see the post by might abacus for the inside), unless HP integrated it into the mobo.
  6. idiscuss
    idiscuss Pen Pal - Newbie
    60
    That is why I picked up a dv2500t instead, it has everything I want: better graphic cards, HDMI output, Firewire, clear screen, bigger right shift key and much much longer battery life. For sure it is not a tablet, but I don't really need that function after all.
  7. Rudegar
    Rudegar Scribbler - Standard Member
    243
    one could prob use a ExpressCard which had firewire
  8. makryger
    34
    Amazon's tx1220 also lists a firewire...
  9. Rudegar
    243
    i've seen reports of firewire too but
    when hp's sites dont say it have firewire i dare say that it dont
  10. rahulnirmal
    rahulnirmal Pen Pal - Newbie
    33
    Nope, it doesn't have firewire, period.
    But yes, you could add an Expresscard to add a firewire port.
