Fingerprint Reader Problem - HELP!
Discussion in 'HP Elitebooks' started by lovelaptops, Sep 17, 2010.
  1. lovelaptops
    2,605
    1,112
    After so much waiting, I finally got my replacement 2740 with an SSD and been loving it, only to find that the fingerprint reader is problematic. I have had a lot of HP machines with FP readers and really know how to swipe them to enroll and use them, but it's been taking 50-75 swipes to get a fingerprint enrolled, and then of course it almost never works to log on, because it's so fussy.
    I'm afraid this is a hardware problem - either a bad sensor or the sensor is misaligned with the opening on the side, meaning sending back for a replacement (there is still time in my 30 days on the new one) seems the only solution.
    Anyone know of a software solution to mis-calibration of the FP reader? I so don't want to send this one back!
    Thanks.
  2. 970261
    970261 Scribbler - Standard Member
    334
    Not sure if true (disabled fingerprint on my 2730p), but i heard that you're suppose to only "touch" the reader with the finger/fingertip and not "swipe" it.
    Weird, yes. But kind of makes sense...in a weird way.
  3. in4mer
    277
    I think I had the same problem with you. What I did was i had originally used my index finger but I read in the other thread I created about this, to use your middle finger. That actually fixed my problem so I went from 35% first scan login rate, to about 95% first scan login rate.
    Added:
    http://forum.tabletpcreview.com/hp-elitebooks/34215-2740-fingerprint-scans.html
    That's ironic. Your suggestion fixed my problem. I hope the same suggestion fixes your problem. :)
    But seriously. I had the same problem you have. I would scan the finger prints to enroll them 30 times before I gave up but your suggestion with the middle finger, worked!
  4. lovelaptops
    2,605
    1,112
    Thanks for the help. I actually found yet another potential source of the problem and it worked like a charm for me before I got to see these ideas. It turned out that somehow the reader software thought I already had enrolled my index and third finger (I hadn't, honest! :), so I had to uninstall the HP Protect tools software and reinstall it with a "clean slate" on fingerprint enrollment. It worked perfectly - 2 swipes and it enrolled my index finger and third finger. I believe there is an easier way to empty the fingerprint register and restart, but I couldn't get it done without uninstalling the Protect Tools software overall.
    Oh, and, BTW, it turned out that each time I swiped my finger and it registered that it had not enrolled successfully (lights up red for a sec or two) there was a little flash of text that said: "this fingerprint already registered."
    Strange stuff, but so useful to have that FP reader for logon and websites. Thanks again.
Similar Threads - Fingerprint Reader Problem
  1. Kumabjorn
    374
