Fall Creators Update 1709 issues
Discussion in 'Windows 10' started by WillAdams, Oct 21, 2017.
  1. WillAdams
    1,029
    463
    Updated. Regret it. Issues:
    - can't drag select text with the stylus
    - can't shift-click to set up a selection with the stylus
    - in some QT apps (Carbide Create in particular) it's impossible to select a drop-down menu
    doobiedoobiedum likes this.
  2. ATIVQ
    ATIVQ V⅁O⅄ Senior Member
    1,046
    589
    Yeah that's a real head-scratcher. Microsoft is pushing digital pens really hard and they destroy such a widely-used feature.
    WillAdams likes this.
  3. Selofain
    Selofain Chronic Lurker
    538
    305
    I, too, think this is a weird change. Why make the pen behave like it does in Android? Why make the pen more like touch? The pen has always been a mouse replacement and touch has always been something else entirely.
  4. jnjroach
    4,087
    1,490
    With the Surface Pen if I click the button on the barrel it allows me to scroll by pen flicks....
  5. Selofain
    538
    305
    That actually reminds me, this new update completely breaks pen flicks for me. I use it pretty frequently to paste screenshots into posts, and now I can't do that anymore. I have to go back to right click > paste.
    Windows should maybe stop trying to be clever and gutting their own features, yeah?
    Edit: Oooookay, I can no longer click and drag things. Including urls (to new tabs) or layers to the trash bin.
    Yes, there are workarounds, but why should they be necessary?
    Also, while the TIP is mostly fixed for me, I still get the bug where the first letter duplicates itself. But it duplicates itself outside of the writing window, so I have to arrow all the way back to delete it, or delete everything, then the extra letter, and start over. It's annoying.
  6. WillAdams
    1,029
    463
    Rolled back, and now need to figure out how to keep the update from installing.
  7. Azzart
    2,246
    1,564
    You can try, for now, to look for "Services" and disable windows update.
  8. WillAdams
    1,029
    463
    Thanks. I just don't get how this could get through testing --- how can one use the system if one can't select text?
  9. surfaceproartist
    2,930
    1,893
    In Windows 10 1709, the pen is set to ink by default. In Word, go to the Draw menu and click the Select icon. Now you can select text with the pen. In Edge, hold down the pen button as you drag across the text and it will select.
  10. ATIVQ
    1,046
    589
    That's fine for Word and Edge, but both scrolling and selecting text is completely bungled in other software.
