Faint Clicking Noise
Discussion in 'EP121 Slate' started by Hugoneus, Mar 7, 2011.
  1. themike
    themike Pen Pal - Newbie
    i got the sound get going again (lot of screen action seems to trigger it, so maybe it is the screen?) and tried to record it via phone and vid cam.
    unfortunately, the fan noise masked the clicking noises so i had to ditch that effort. Then I got to thinking and gave ep121's own mic a try and lo and behold, crystal clear recording of the noise.
    YouTube - ‪ep121 clicking noise‬‏
  2. Grimspoon
    Grimspoon Scribbler - Standard Member
    135
    Sounds mechanical, which rules out pretty much everything but the fan?
    My guess; it's the fan's bearings.
    Edit; have you been able to confirm for sure that the sound isn't emanating from the speakers themselves?
  3. themike
    yep, killed the volume as the clicking went...and clicking kept clicking
  4. CF77
    2,303
    sounds like metal parts rubbing.. may be some parts are not screw down tight. may even be the fan. only way to find out isto open the backcover and have thunit run..
  5. coldpenguin
    coldpenguin Scribbler - Standard Member
    279
    At first sound, I thought it might be a bearing.
    But then you hear it click, and kinda reverb. If it were the bearing I wouldn't expect the reverb.
    Strange. Do your fans ramp up when under load?
  6. daveyd007
    daveyd007 Pen Pal - Newbie
    54
    <....."seems to occur with constant screen changes".....>
    @ themike- are you shaking/rotating the slate to get that noise? Is it coming from the pen slot when the pen is removed?
    When I take the pen out, it makes a ball bearing like metallic clicking noise if shake the slate. Put the pen back in and shake, the noise goes away. I'm sure the noise I am hearing is coming from the pen holder when it's empty. At least mine is like that.
    Anyone else share similar results?
  7. e-schreiber
    2,629
    59
    That's exactly the sound my HP TM2 makes! :eek: I have a regular Hard Drive, though. I always thought it was the HD, but now I doubt the HD is the culprit. I don't think it's the fan either.
  8. themike
    fan does ramp up accordingly to the load on the processor... no rattles when shaking the tablet... i'm starting to suspect it's some kind of electrical charge. As someone mentioned it in the past, it only occurs at landscape mode from the left side, so that leaves the pen holder out. The unit has been shipped to asus and back and seeing how they opened and closed it back up, i don't think it's some loose part. I'm seeing a correlation between screen activity with the sound (ie. scrolling up and down on freshly loaded pages) so maybe some faulty screen unit?
  9. daveyd007
    54
  10. e-schreiber
    2,629
    59
    It does sound the same, but a lot more frequent.
