F3507g workaround: Use WWAN card without third party software and utilize the GPS sensor
Discussion in 'Toshiba' started by semalb, Oct 10, 2009.
  1. semalb
    semalb ♂
    133
    Dear you,
    I've finally managed to use the default connection manager with my F3507g card.
    Basically, you have to extract drivers from the MSI package from Lenovo drivers (which supports windows 7 default connMan) and replace drivers provided by toshiba: MANUALLY!
    I'm posting some images as proof, and working to create a guide. Unfortunately there's no way to install drivers using lenovo's msi as it does some sort of authentication to the device before installing. However, once manual installation is done, the device works like a charm. It actually connects at 7.2Mbps this means i'm using HSDPA: too bad there's no way to look which network you're using.
    Advantages are: you can finally have GPS sensor listed on Location and Sensors tab, and you can connect to WWAN without the need of 3rd party applications.
    Images follows, i hope i have time to post a guide soon.
    [​IMG] [​IMG]
  2. TabbedOut
    1,369
    Please post a guide, as soon as you do I'll update the M700/M750 hardware info page.
    Good job!
  3. semalb
    semalb ♂
    133
    Hi TabbedOut. Please wait before adding this to HW/SW thread. I'd like someone else to test this solution before.
    Disclamer:
    - This procedure does not add any new feature to your Mobile Broadband.
    - Installing this drivers in place of toshiba F3507g standard drivers is *not* supported by Toshiba, nor by me.
    - This guide is provided as is, and is still beta. I've just tested it for one day, and it seems to work. However, i can't provide full assurance that future fixes or updates won't break the functionality provided.
    - This guide involves manually installing/uninstalling drivers: although i think it's almost safe, this could cause damage to your operating system (not your hardware) and may require a full reinstallation. Unless you feel comfortable with steps listed above, please, wait more expert users to test this before apply.
    - Please, to avoid data loss, backup important data before applying.
    - This procedure has been tested on x64 bits of windows 7 only, although it should work on x86 operating system.
    Objectives:
    Windows 7 introduced a new api for GPS and Mobile Broadband devices, which are now supported out of the box. However, new drivers are required for both mobile broadband modem and GPS sensor to be correctly recognized. Toshiba provided new drivers compatible with Windows 7, however, they are not compatible with new api, thus still requires 3rd party software to:
    - Enable/disable GPS.
    - Enable/disable/connect to mobile networks.
    Lenovo provided drivers which perfectly fit with new apis allowing both devices to be managed by operating systems. However, during installation, a check is performed over the device, which aborts installation. The objective of this guide is to use theese drivers with our Toshiba F3507g, removing the need of 3rd party software. OS components should be more stable than 3rd party applications.
    Walkthrough:
    1) Log on as Administrator if you run your environment under limited privileged user.
    2) Remove "TOSHIBA F3507g Mobile Broadband Device" drivers from Control Panel / Programs and Features. Please note the removal should only uninstall hardware but not remove completely the drivers. Don't worry about this. Do no reboot. The OS would detect the device again and install the crappy toshiba drivers.
    3) Download the file HERE. This file contains x64 bits only drivers and catalogs (sorry x86 dudes, i haven't a x86 environment) manually extracted from lenovo MSI and unified in a single directory. Extract that folder on your desktop.
    4) Open the Device Manager under control panel. Right-click on the root of the tree (where the name of your computer is shown) and choose "Scan for hardware changes". A new hardware should be detected (woah!) and windows should ask you drivers. If this is not your case, you should find a warning USB device named "Toshiba F3507g bla bla bla" under your USB devices in device manager.
    5) Double click it and choose the Driver tab. Choose Update Driver.
    6) Click "Browse my computer for driver software" then choose "let me pick from a list of device drivers on my computer". A new windows should appear. Click the "have disk" button.
    7) On the new window, click browse and navigate to the folder you have extracted files. Should be something like "<yourdesktop>\3G Ericsson Drivers\Unified". Then click "OK".
    8) Choose the signed "F3507g Mobile Broadband Device", the one with the certificate next to the name.
    9) Allow your system to install the driver.
    10) Reboot.
    The system should find all other five (5) devices as shown in figure automatically. I say should, becouse i've found with manual installation this is not always true, and i can't explain why.
    At the end this is how the system should be (yeah you got it, i haven't yet installed the AMT drivers). If this is not your case, you will have problems.
    NB: Again, this post is provided as is. If any experienced user can give it a try, i can offer him remote support, if something goes wrong. Please note i'm offering support to experienced users only, in this first stage.
  4. semalb
    semalb &#9794;
    133
    UPDATE: Based on my research (you can see them on the screenshot above), i'm actually using mixed drivers. Some are installed from toshiba drivers for windows 7, some others from the package i've provided.
    The three drivers which i suppose needs updates are:
    - The GPS Driver (Which uses w36wgps.sys and e32gsen.dll)
    - The Toshiba F3507g Mobile Broadband Network Adapter (Which uses the WwanUsbMp64.sys)
    - The F3507g Mobile Broadband USIM Port (which uses standard microsoft drivers scfilter.sys provided by Ericsson)
    I suppose you just need to upgrade them to get connection manager support to F3507g.
    I'd like a user to try updating them before trying updating the whole drivers (which can result in an error). All catalogs can be found in the "Unified" foler.
    I think the drivers from the network adapter are required from the connection manager, while the drivers from the gps are needed by "devices and printers" to recognize the GPS Sensor.
    If you have any feedback, i'm waiting.
  5. andre217
    andre217 Pen Pal - Newbie
    Hi!
    I would like to test the drivers.
    ...but the rapidshare link is down :-(
    Can you upload it again?
    Thanks,
    andre217
    //Edit:
    For what I need the drivers:
    I have bought a Dell wireless-wan card and I have a Lenovo notebook. I think, that the cards are in general the same, so the drivers should work. My only problem (at the moment) is, that I can't extract the drivers from the Driver Packages they provide.
    I think that the Dell package wants a Dell notebook and the Lenovo package wants a Lenovo card...
  6. semalb
    semalb &#9794;
    133
    Hi andre, i'm not sure drivers provided may fix your problem. I've found Dell usually customize hardware more than other builders.
    However it's worth a try. Please again, note i can provide x64 drivers only as i've dropped "legacy" x86 right after windows xp x64.
    I'm sending you the package this evening, (GMT+1) as i'm at work now.
  7. andre217
    Thank you! I have Found no other good Solution until now... I think it is worth a try.
    I would like to Know how you got the drivers extracted from the packages... I had no sucess with the Universal extractor. Is there a better way to do so?
    Thank you very much!
    (damn iPhone German spelling Correction ;) )
    ps: i am using Windows 7 Pro x64!
  8. semalb
    semalb &#9794;
    133
  9. andre217
    It works!
    Thank you very much! At this moment I am online via the Dell WWAN Card.
    Drivers are included in your package. The installation isn't really difficult.
  10. TabbedOut
    1,369
    Thread stickied and renamed (hope you will forgive me semalb, but I wanted the contents to be clear for future searchers).
    Good job!
