Evernote sync problem
Discussion in 'Asus (Android)' started by sezat, May 22, 2012.
  1. BlacKnight
    184
    Hi TheTwo
    I have tested v0.6.4.4. It works flawlessly :) Thank you so much for working to fix the problems. FPDFAM will now be really useful to help me transfer my notes from the Eee Note to OneNote.
    I will try and fix up my templates so that they don't conflict with the Eee Note naming convention.
  2. TheTwo
    TheTwo Scribbler - Standard Member
    102
    Hi,
    when you change the naming of the templates, don't change the folder name in which the png files and the Template.xml are located. Otherwise, you may get problems with notebooks that allready uses the old version of the templates.
    TheTwo
