eReader with translator incorporated?
Discussion in 'Software' started by willowD, Apr 5, 2015.
  1. willowD
    willowD Pen Pal - Newbie
    I'm using Nook, but i'd like to know if there are any app where you select a word from the text and then it gives you the option to translate it from one language to antoher.
    Thanks
  2. Kumabjorn
    4,309
    2,370
    Kindle lets you select the dictionary you want to use with a book, that goes for the Kindle apps as well. Most of the dictionaries are monolingual, but there are some that translate to other languages as well that come for free. You can purchase a commercial dictionary for Kindle and then install it as the default dictionary. The best place to find this kind of information is on Mobileread.
    Balbutio ergo sum
    willowD likes this.
