EP121 replacement power adapter
Discussion in 'EP121 Slate' started by amademan78, Aug 18, 2011.
  1. amademan78
    amademan78 Pen Pal - Newbie
    Anyone try any aftermarket power adapters? I just received my slate and would rather not carry the power adapter to and from work. So a second one would be ideal but really don't want to spend what Asus is charging for one.
    Any recommendations? I see plenty on ebay but who knows how well any of those will work.
  2. Steve S
    7,756
    3,241
    <<...Anyone try any aftermarket power adapters?..>>
    made: I believe that other EP-121 users have had good results with the innergie AC adapter:
    Notebook Adapters Overview
  3. ravisurdhar
    ravisurdhar Pen Pal - Newbie
  4. ravisurdhar
  5. RamboPreacher
    RamboPreacher Geek
    mine didn't come with the correct tip, but a quick email to them and they sent me one free.
  6. JustPlainDon
    JustPlainDon Pen Pal - Newbie
  7. LanMan85
    LanMan85 Pen Pal - Newbie
    To whom did you send an email requesting your free tip? Innergie, or ASUS?
  8. CF77
    2,303
    ASUS power unit does not have interchangeable tip. you just want a free tip..do you? without a EP121>
  9. furythree
    furythree Pen Pal - Newbie
    75
    so any aftermarket brands on ebay? wats the voltage i need to look for?
  10. amademan78
    I Bought the same one as JustPlainDon from ebay seller utopiadreamglobal. The first one that was sent was loose and did not charge at all. I emailed them, send it back (out of my pocket) and the replacement they sent was a perfect fit. Cost me a few extra dollars to send it back but still much cheaper than the Asus OEM replacement.
