Enable tm2t GPS?
Discussion in 'HP TouchSmart TM2 (Wacom)' started by hoongss, Apr 15, 2010.
  1. hoongss
    hoongss Pen Pal - Newbie
    60
    uhm... if u want, i can vpn to ur com and try to install it for u
  2. BlindWolf8
    BlindWolf8 Comparer of tm2s
    285
    Hi hoongss,
    No, I don't think that's necessary. Right now there's no driver installed. I'm going to simply install the driver you mentioned, reboot, and let you know what comes up in the Device Manager now. I'm assuming that's what you would do when VPNing in as well, correct?
  3. BlindWolf8
    285
    OK, installed the driver, saw it install, rebooted for good measure, NMEA's not there. As a note, when I installed the driver, the WWAN interface was OFF via the HP Wireless Assistant. I turned WWAN on for good measure after it was installed to see if it found anything extra. NMEA still was not found.
  4. BlindWolf8
    285
    Other notes:
    Reading through the installation window for the EXE downloaded from HP for the latest Gobi driver for the tm2, (not the 311 as you mentioned) it looks like some firmware is updated.
    Also, if I don't have a SIM card (which I have never inserted into my tm2) and select a provider, and hit Back in the wizard, I see a lot more providers than Sprint and Verizon Wireless.
    The providers it lists are:
    • AT&T
    • Orange
    • Sprint
    • Sprint International
    • Telecom Italia Mobile
    • Telefonia
    • T-Mobile
    • Verizon International
    • Verizon Wireless
    • Vodafone
    • Other Provider
    Also, if I select Sprint, I noticed a driver was installed for this device: "HP un2420 HS-USB QDLoader (COM5)".
  5. hoongss
    60
    Well, another thing I install before I got the NMEA is MS Streets and Trips Trial edition.
    I dont know if this will helps, but u can try..
    Let me know
  6. heatlesssun
    2,320
    So to be the ignorant one but has anyone gotten GPS to work?
  7. dantedrac
    dantedrac Pen Pal - Newbie
    39
    Aye mine works flawlessly as well as hoongss. (Works great via MS Streets 2010, google earth, etc.)
  8. hoongss
    60
    Yea. Dantedrac guided me thru the process + some playing around.
  9. heatlesssun
    2,320
    Do you have a quick list of what you did? If its in the thread mind pointing me to it? As I said earlier I have Verizon so I don't know if that matters.
    Thanks again!
  10. hoongss
    60
    Yea. Look at page 2 of this discussion.
