Elitepad 1000 boots into HP ENTERPRISE. HELP!
Discussion in 'Hewlett Packard' started by nannlp, Jun 22, 2016.
  1. nannlp
    nannlp Scribbler - Standard Member
    84
    100
    Hi,
    Thank you for guiding me .
    Couple of months ago my friend visited me and lobbed the eleitepad , he went on ebay and purchased the same for a bargain but never really turned on the machine .
    anyone
    last time he visited me , he gave the machine to me requesting for a set up similar to mine.
    Last night I turned on the machine and it only starts cmd with a HP ENTERPRISE Logo below then continues to set up asking for email and name .
    I am able to bet into the BOOT MENU and see the options or change it .
    Does anyone suggest an erase disk from BOOT and then clean install windows 10 from a USB ?
    PLEASE HELP!
    p.s : My friend wrote to the ebay seller and got a reply saying he had no clue about it and had sent it to HP BATTERY REPLACEMENT and never had turned it ON!
  2. nannlp
    84
    100
    Solved !
    Just got a BOOTABLE USB (FAT32 WORKS NTFS does not work) with WINDOWS 10 and installed .
