Eliminate screen grainiess by removing digitizer for tx2000?
Discussion in 'Hewlett Packard' started by DRTigerlilly, Sep 30, 2010.
  1. lowlife
    lowlife Addicted to gadgets
    99
    You sound happy about the mod. Have you tried it outside yet?
  2. whazzup
    531
    32
    updated first post with pics and a video
    yup, tried it outside, slightly brighter, slightly better viewing angles. Not a lot, but still great! XD
  3. kanehi
    kanehi Scribbler - Standard Member
    197
    Kinda scary taking out that screen. A thin black soft foam adhesive might do the trick in sealing that gap.
  4. atom
    atom Pen Pro - Atomic Member
    606
    If you got a slightly thicker screen protector (Lets say the same thinness/thickness as the passive digitizer) then I doubt you would continue to see those "ripples".
  5. roflballs
    roflballs Pen Pal - Newbie
    21
    Hmm... I was just wondering, is the inner LCD matte or glossy finish? I assume its matte from the video & photographs, as well as the ripple effect (glossy screens are usually more rigid). Also, they would have no reason to put a glossy screen on the inside...
    As such, if the LCD inside is matte finish, how is the glare compared to the passive digitizer? Is it of comparable quality/finish to standard laptops?
  6. roflballs
    21
    Just another thought... Does anyone know the dimensions of the touchscreen? (including thickness) I'm wondering if it could be replaced with just a thin sheet of glass or plastic to fill in the gap, prevent ripples, and protect the screen at the same time.
  7. octagonalman
    octagonalman Pen Pal - Newbie
    73
    I think it'd also be interesting to see how much the mass of the unit has been reduced by taking the touchscreen out.
  8. nayato
    nayato Pen Pal - Newbie
    Hi all. Just thought if it will have the same effect to remove the touchscreen film only. You can check that if you'll press the film strongly so it will stick to the glass behind there will be much less graininess in that spot. So probably this film as the root of problems. What do you think, will it be possible to just cut it off leaving the glass in place?
  9. nayato
    So I finally did it. Now I have a crystal clean screen with much better viewing angles! BTW I have no metioned gap between bezel and screen as the film was quite thin. Now I'm considering use of screen protector as a glass itself feels a bit scratch-catching. Yes, it will add some minor negative effects to overall screen experience but it will definitely be not so irritating to my eyes.
  10. whazzup
    531
    32
    nice! i tried looking at mine, and the film is indeed peel-able. But peeling if off seems to tear and affect the sensor threads around the edge of the glass, and i believe that may render it useless. Then again, the advantages of a clear screen is clearly.....very clear.....
    and try the photodon protectors, they're good.
