Dynapad 2in1
Discussion in 'Toshiba' started by nannlp, Oct 6, 2020.
  1. xxxxx
    xxxxx Pen Pal - Newbie
    33
    14
    related to servicing, from the german video review above, the chassis screws are cross-shaped, look like standard phillips screws.
    the only thing I don't like about this dynabook portégé is the non-standard keyboard layout: in standard iso layout, the VK_OEM_2 key should be between the left shift and the `Y` key, but here it's on the bottom row, right of `alt gr`... not a deal breaker, but normally I use this key a lot for shortcuts as it's easy to hit with shift/ctrl/alt Maxthon_Dynapad_2in1__TabletPCReview.com_-_Tablet_PC_Revi_20210511_axmKMX10H9.png
  2. daddyfish
    daddyfish Scribbler - Standard Member Senior Member
    704
    501
    , you mean among others things for the task manager shortcut? Cause you can also do the latter through ctrl+shift+esc.
  3. xxxxx
    33
    14
    uh? l wasn't even aware you could use VK_Oem82 to invoke the task manager :D
    I use it for zoom/tool switching in storyboarding/art softwares, I don't mind qwerty/azerty, but I need a real ISO layout to work
