Drawing Win device, Cintiq 13HD replacement
Discussion in 'What Tablet PC Should I Buy?' started by jubey, Sep 27, 2016.
  1. jubey
    jubey Pen Pal - Newbie
    14
    Hallo guys and gals.
    I am looking for a mobile drawing device to replace my Cintiq 13HD, which performance I really love but which flexibility I don't.
    lets start with that one:
    1. What is your budget?
    the less the better ;), but with the option to sell my Cintiq which is in a very good condition.
    would prefer not to
    I would prefer a Convertible, but a 2in1 Tablet would be ok too. It has not to be superlightweight…
    12-14"
    Germany
    Not really, but I want to use it for some years.
    I am ok with am medicore battery life, but a (somehow) replaceable battery would be nice.
    Drawing (high Resolution, 12Mp an more). Some photo editing, surfing, light gaming too, but it’s not the focus since I have a solid workstation too.
    Windows
    Mainly PS (CS6), Krita
    Maybe some 2D, nothing demanding
    No
    Screen Specifics
    FHD maybe more, but too fine resolutions could cause problems with PS CS6. I am very ok with FHD on 13" btw.
    Not that important
    I really like drawing on my Cintiq. Offset at the edges is not a big problem for me. To have too much pressure to activate (like I heard the Surface has to deal with) would surely be a problem. As well as drawing on a slippy glass panel. I also use a Galaxy Note 8.0 with a mat protector, which is fine.
    Component Specifics
    128GB and up, 8GB Ram would be fine or at least the possibility to expand.
    HDMI out would be great, more than one USB too.
    Another important point is noise. Fanless would be nice, but I am not sure if a m3/5/7 would be fast enough for my needs. At least a nice fan-characteristic would be important. Something you can use in bed at night without getting mad. I had a Fujitsu T902 some years ago and it was way too noisy imo. and with ups and downs all the time. Had to send it back, sadly.
    Hope you can help and thanks for your time.
    Bye
  2. surfaceproartist
    2,930
    1,893
    Lenovo Thinkpad P40 is not as good a deal as the Thinkpad Yoga 14 which is sold exclusively in the US, but I think it ticks most of your boxes.
    No recent lower cost convertibles utilize Wacom EMR, the pen tech found in your Cintiq 13HD. The closest you'll find is the Wacom Cintiq Companion 2, which is due for an update and doesn't meet your fan noise criterion.
    jubey likes this.
  3. jubey
    14
    yes, Companion is too expensive and there seem to be too many problems (as you mentioned). Sadly.
    Anyway, I dont insist on a passive pen...
    The newest Yoga 14 (called Yoga 460) in fact is available here in Ger, and was so far one of my favorites.... The question is, can it replace my Cintiq + PC?
  4. surfaceproartist
    2,930
    1,893
    The TPY 14 has a discrete gpu which the 460 doesn't (in the US). It performs very well but depends on the desktop you're looking to replace.
  5. surfaceproartist
    2,930
    1,893
    The only real desktop class tablet is the VAIO Z Canvas.
  6. Azzart
    2,242
    1,563
    If you're going for ntrig or Wacom aes though, I wouldn't be completely sure photoshop cs6 and Krita will work well with those.
  7. thatcomicsguy
    3,290
    2,346
    AES might drive you crazy. Or not. I find I can't rely on it exclusively. I do pencil work on my AES Dell where drawing speed is high and accuracy isn't vital, and then I do precision inks back home on my Cintiq.
    The Fujitsu Lifebook t904/935/936 uses EMR at the same screen size you're used to, but it offers higher resolution. It's a very elegant 2-in-1.
    It ought to make a suitable replacement.
    There have been mentions of the plastic hinge covering deforming over time, but from what I gather this is merely cosmetic, while the metal hinge component remains strong.
    It's an expensive machine, but it's the last of the last modern EMR devices available. If I could get by with a 13.3" screen, I'd probably get one myself. I just think it would be too small for my comfort level.
    jubey and Starlight5 like this.
  8. surfaceproartist
    2,930
    1,893
    Krita isn't a problem on AES machines as long as you can install the Wacom Feel driver for Wintab support. PS CS6 is a different story. Either upgrade to Photoshop CC ($120 annually) or find another modern alternative.
    Azzart likes this.
  9. jubey
    14
    Ok, thanks a lot!
    Seems more complicated then expected... I should try an AES device first.
    Meanwhile I could give that cube i7 book a try, maybe it is sufficient in combination with the Cintiq/Desktop for my needs.
    e: That Lifebook sounds nice, but i doubt that Fujitsu got rid of that annoing fannoise/characteristics (in my first post I was talking about Fujitsu T902 I had problems with, not Toshiba btw. ^^ edited that).
    And it's really expensive...
  10. Shogmaster
    4,265
    1,505
    I've found CS6 to be severely gimped by new Wacom Wintab drivers with weird errors, such as intermittent loss of pressure every few stroke. Error totally went away when I switched to CC. I have a conspiracy theory about this in my head...
    jubey and thatcomicsguy like this.
