double stylus
Discussion in 'Panasonic' started by SimsHsia, Oct 13, 2007.
  1. washactun
    washactun panasonic cf-18 toughbook
    i'm looking for a two-way stylus pen for my new panasonic cf-18 toughbook (windows tablet pc version, wacom digitizer screen) -- with a digitizer tip at one end, a ballpoint at the other.
    I guess i'm spoiled by the convenience of true-tip pen caps, which turn a ballpoint pen into a two-headed stylus for my (touchscreen) ipaq pda.
    I'm using a panasonic stylus pen (cf-vnp005u), which is barely OK.
    panasonic brand stylus pens seem to have limited options.
    Am I stuck with them?
    Or is there some way to find out which brands/models of digitizer stylus pens are compatible with the cf-18 -- other than just buy and pray?
  2. SimsHsia
    3,293
    Hi washactun,
    You'll have to look for stylus pens with the "Wacom Penabled" sticker or certification on it, e.g.:
    I'm not sure if you'll find a stylus pen with both a ballpoint pen and the other portion to be compatible with a Wacom digitizer; if you do find one, please do let us know! :)
    In addition to buying a third-party stylus pen, the stylus pen you plan to buy will most likely not be able to fit in the stylus pen garage or slot; you'll have to carry it around with you, or tether it, or velcro it somewhere to keep in handy when needed.
