Does the Venue 8 Pro work with other styluses?
Discussion in 'Dell' started by Shayes, Mar 23, 2015.
  1. Shayes
    Shayes Pen Pal - Newbie
    46
    I am specifically asking if it works with the stylus that comes with the Lenovo Thinkpad Tablet X220T. Also interested if there is any other different stylus that might work with it.
    I have a X220T and was wondering if I could get a Dell V8P and not buy their $50 stylus pen. also ive heard those are having problems, so i would like to keep using mine.
    edit: i tried and model 3845 V8P doesnt work with the X220T stylus (Wacom digitizer stylus) and doesnt work with the dell active stylus (active capacitance stylus).
  2. Mikerman
    1,293
    126
    I'm not sure what other active styli the DV8P will work with--my hunch is, it will work with the HP active stylus, as the Dell active stylus will work on an HP system (at least, with the HP Pavilion x2); although the HP active stylus tends to cost significantly more than the Dell version. And, of course, any capacitive stylus will work with the DV8P.
    But no need to spend $50 on the Dell active stylus, at least in the U.S.: Dell.com currently has it for $34.99, before applying any coupons or discounts that often can be found (and shipping, as well as any returns, can be free). http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&orig_s=gen&sku=750-aagn&s=dhs I believe that it also sometimes has been sold by Dell for less, as well--the price can fluctuate.
    And from all reports, the current version of the Dell active stylus works well--the earlier, unfortunate "kinks" were worked out.
  3. Shayes
    46
  4. FZelle
    763
    169
    They mean those 20c sticks that have a big rubber, and are not smaller then your thumb.
    You can't really call those a stylus.
  5. Shayes
    46
    yea im thinking its just a regular piece of plastic stylus with a tip that resembles a fingertip
    i wonder how small that tip could theoretically be though...
  6. Mikerman
    1,293
    126
    I've seen some that are smallish-pointed--but they are not inexpensive.
