Does the slate have a max limit for the SD card slot?
Discussion in 'HP Slate' started by 2jz gze, Dec 4, 2011.
  1. 2jz gze
    2jz gze Pen Pal - Newbie
    Sorry I tried to search but couldn't find the answer. Basically what size sd card can the slate handle?
    TIA
    Julian
  2. Boyd
    Boyd Pen Pal - Newbie
    61
    Don't know, but I have a 32GB SDHC card in mine and it works fine.
  3. 2disbetter
    2disbetter Function over Form
    350
    It would appear that it supports sdxc cards which has a current limit of 64gb. However this isn't the real limit. As soon as technology allows for larger capacities it should support it as well.
    128gb is the current max for that format.
    2d
  4. Steve S
    6,474
    2,115
    <<...It would appear that it supports sdxc cards which has a current limit of 64gb...>>
    2d is correct. If I recall correctly, an SD card slot that supports SDHC will also support SDXC. So you should be able to use any current SDxx card in your Slate.
    Note that just like any other product, users have reported various experiences with different brands of cards. Card failures are not rare, but they're also not common. In many cases, you get what you pay for...
  5. revmike
    revmike Scribbler - Standard Member
    444
    61
    I have a 64gb sandisk sdxc card in my slate and it works perfectly.
  6. 2jz gze
  7. ships10
    1,522
    180
  8. revmike
    444
    61
    I saw that card and seriously considered buying one, but I think for that price I would rather have a 128gb ssd drive instead. Ships10 that is a much better price.
  9. Bronsky
    6,801
    2,982
    Nice price. Still haven't made a dent in my 32GB SD :eek:.
  10. ships10
    1,522
    180
    I am also seriously considering buying a 128gb ssd and putting it in the slate.
    I was able to pry open the slate (required some fine handywork!)to look at the ssd...it is very possible to replace it. Oh, I did put it back together...in case you were wondering...with no deleterious effects on the slate ....lol!
    There is one for $239 : MyDigitalSSD 128GB Bullet Proof Half Slim SATA II SSD | My Digital Discount
    Yes, this would fit perfectly into the slate. It is the half slim type....just what the doctor ordered!!
