Does Surface Pro 3 Type Cover work on a Surface Pro 2?
Discussion in 'Microsoft' started by lancorp, Sep 15, 2014.
  1. lancorp
    lancorp Scribbler - Standard Member
    141
    As the title says, and we don't care that the keyboard is bigger than the SP2.
    Looking for basic keyboard and touchpad functionality. If so, special drivers needed on SP2?
  2. Steve S
    6,474
    2,115
    <<...Looking for basic keyboard and touchpad functionality...>>
    ...Yes, it does. I typed some sample sentences in Word and tried basic pointing and two-finger scrolling on the touchpad. Basic functioning seems to work.
    Of course, probably because of the size mis-match, closing the Pro 3 Type Cover on the Pro 2 does not cause the Pro 2 to go to sleep. But you can always use the I/O button, which is what I do...
    Mesosphere likes this.
  3. SAM 2013
    830
    210
    The Surface 3 cover works on the Surface 2 and viceversa.
    The cover is quite abit larger, but if you do not close it, then it
    does not matter.
    The mouse pad on the Surface 3 cover is aot nicer and the
    keys now light up. But, there is no magnet to prop up the
    keyboard. Put something under like a dowl and it is now
    propped up...
