Does CPU speed effect battery life?
Discussion in 'Asus' started by techaholic, Nov 9, 2006.
  1. mthode
    mthode Pen Pal - Newbie
    22
    I am looking between a T7200 and a T5500 and want to know if I will take a hit in the battery life?
  2. MilestonePC.com
    MilestonePC.com Scribbler - Standard Member
    146
    The answer is yes, but your estimate loss is about 5-10 minutes.
    Each CPU has their voltages in which it affects the battery life, so technically going for the slowest CPU would yeild better batterylife, however many don't care about 5-10 minutes, they rather have the satisfaction of having a 2.0GHZ than anything lower.
    So that choice of the CPU will be up to you.
  3. mthode
    22
    Thanks for the info. The trade is a good one as far as I am concerned.
  4. techaholic
    techaholic Pen Pal - Newbie
    27
    The 2.0Ghz ROCKS, I'm using the pen to write this reply in 64 bit Vista. It is so COOL.
