    31.0%
    52.9%
    0 vote(s)
    0.0%
    6.9%
    9.2%
  1. SAM 2013
    859
    221
    Cool idea, the guitar pick.
    Plastic vs metal against glass.
    What did they repair on your warranty?
    Did they replace the cable or just reload your operating system
  2. Mesosphere
    5,315
    2,065
    In this case it is plastic against plastic. The back cover is what is removed, not the screen. That's why this whole process is so incredibly easy compared to say ... the Surface Pro =)
  3. Mesosphere
    5,315
    2,065
    Update:
    3 days since my digitizer cable replacement
    8 days since my touch cable straightening, re-seating
    Still going strong =)
    Also I received my second try touch cables yesterday, so snail mailing them only took 2 days with no holiday weekend interruption.
  4. michaelws
    michaelws Scribbler - Standard Member Senior Member
    783
    114
    Very much appreciate the daily updating...gives us hope... If you tore of this on a daily basis maybe you could drop back to a week or even tell us if they fail...meaning until we hear you tell us it isn't working then we will assume no news is good news.
    It is reassuring that this little gem might sustain over the longer haul. Thanks again Mesosphere.
  5. Mesosphere
    5,315
    2,065
    Yea the cadence will drop off sharply soon =)
  6. SAM 2013
    859
    221
    The screen is glass?
    Is there an inner plastic liner between the screen and the back?
    The Surface Pro tear down video is ridiculous how Microsoft constructed
    their tablet. Talk about user unfriendly.....at least a hot gun is not necessary
    for the Asus. Should be easy to change out the HD too.
    Do you have to reheat everything to reassemble it? Have not seen any info
    putting it back together again.(Surface PRo)
  7. solitaire01
    solitaire01 Pen Pal - Newbie
    65
    Yeah, a firm guitar pick is the way to go. :) Not a scratch.
    They actually swapped the entire system board and I bet that included new cables. It did the trick for several months but I didn't have the yellow tape on the cable so it's evident Asus' tactics have changed over time.
    Sent from my iPhone using Tapatalin
  8. Mesosphere
    5,315
    2,065
    It comes apart at the seam that runs around the entire device. It's roughly in line with all the ports and buttons.
  9. fishdavis
    fishdavis Scribbler - Standard Member
    303
    124
    it is REALLY easy to take apart, no screws/no glue, and you just snap it back on (that's the easiest bit). it's the easiest device to disassemble that I've owned. Literally, all you need is a thick bit of plastic to slide the two halves apart. (I used plastic so it wouldn't scratch the plastic back/sides, and it didn't leave any marks, I could see something metal leaving scrape marks). I could see a guitar pick working really well. It got even easier the next time (possibly partly psychological once I realised the plastic back wasn't going to break)
    Honestly, I think it's pretty hard to screw up. is your tablet still having a cable issue?
  10. Sweetpea8472
    Sweetpea8472 Scribbler - Standard Member
    447
    116
    My husband opened his case, starting from the pen silo to the bottom and then along the edges. We noticed the cable has a fairly sharp crease on the bottom loop. But as I already managed to coax his pen to work again (by some soft stroking on the back :p), no idea if it will work the next time :D
    A shorter cable would be nicer though... (even if only for a peace of mind...)
  1. Gerhard
    2,960
  2. jedah
    2,760
  3. daddyfish
    1,715
