    29.8%
    54.8%
    0 vote(s)
    0.0%
    6.0%
    9.5%
  1. cyberspearit
    cyberspearit Pen Pal - Newbie
    4 months since the stylus cable replacement. Still works like a charm! Touch has yet to fail but I'll be ready when it does...
  2. Pierluigi
    Pierluigi Pen Pal - Newbie
    hello everybody! i'm asus vivotab note 8 owner and i have the same issue about touchscreen problem. i would replace the cable but i would sure to order the right one. Can someone that have bought it post the exactly link of the right cable? thanks a lot.
  3. thierryb
    1,380
    291
    Read the first post, and you will have a link.
    But what is better is to search the reference on google. Because you will get a vendor in your country.
  4. snoxu
    snoxu Pen Pal - Newbie
    25
    Can someone tell me how do I reinstall the touch driver?
  5. Kumabjorn
    4,311
    2,382
    Wacom or Microsoft?
    Balbutio ergo sum
  6. snoxu
    25
    Which ever is best.
    In the meantime I replaced both cables. Touch for some reason wasn't working. I installed the old Windows 8.1 SOC package and got touch working.
    I'm on Windows 10 BTW, and there was a warning saying drivers were old, but since I need touch I installed it.
    Anyhow is there a list of recommend drivers?
  7. Kumabjorn
    4,311
    2,382
    Install the latest Wacom FeelIT driver from the Wacom site. Search for TabletPC driver on their support section.
    Balbutio ergo sum
  8. snoxu
    25
    Done. Are the 8.1 SOC drivers still recommended on W10?
  9. Kumabjorn
    4,311
    2,382
    Unless Asus has released a specific Win 10 driver.
    Balbutio ergo sum
  10. snoxu
    25
    OK. Tnx for the help.
    In case anyone cares I got both cables uber fast (two days) for 7,10 euro form a local distributor of Distrelec.
    http://www.distrelec.com/global/
    Hoping these cables will last.
    Kumabjorn likes this.
  1. Luca92
    5,158
