    31.0%
    52.9%
    0 vote(s)
    0.0%
    6.9%
    9.2%
  1. Sweetpea8472
    Sweetpea8472 Scribbler - Standard Member
    447
    116
    I don't need to restart the driver after a nice backrub. At least, as long as I don't reboot with the pen in a non-working state.
  2. eaglestar
    eaglestar Scribbler - Standard Member
    103
    32
    I almost pee my pants after updating wacom driver to ver. 7.2.1-21 and calibration, because touch control went dead. But after restart it seems ok, so, still in Bronsky team. Looks like it is slightly better than 7.2.0-10.
  3. greenblob
    greenblob Pen Pal - Newbie
    93
    Haha, this is ridiculous ...
    But even if the pen dies permanently, $150 for a 64 GB Windows 8 tablet isn't bad ...
  4. Mesosphere
    5,275
    1,978
    Particularly when it can be permanently fixed for less than $5 =P
    Dave47 likes this.
  5. Sweetpea8472
    447
    116
    Maybe I should figure out where I can order two cables one of these days... it seems my tablet likes the backrub better and better...
  6. greenblob
    93
    Very true, but I'm hoping it doesn't come to that, as I broke a nail trying to pry the back open.
    Bronsky likes this.
  7. Mesosphere
    5,275
    1,978
    Yea, I found an old credit card to be less painful =P Only Bronsky is tough enough for that. Tough as nails... and his tablet too apparently.
  8. Yoyo
    Yoyo Scribbler - Standard Member
    My third tablet has finally glitched, the touch screen being the problem this time.
    I'm going to let it ride for now, but I wasn't looking forward to having to pry this one open. Lame.
    It has lasted since July, in constant use.
    Maybe I should drive over it?
  9. w4st
    w4st Pen Pal - Newbie
    I'd gotten used to back-massages and occasionally opening my tablet and temporarily fixing the stylus issue by cleaning and fiddling with the cables. But then the touchscreen started failing too.
    Unfortunately, I'm impatient, so rather than wait for new cables I decided to try something.
    I removed both cables, cleaned them, then applied clear tape to the backsides. Then I trimmed the tape carefully with scissors and plugged the cables back in (with the locking tabs open). Thankfully, the extra thickness didn't cause any binding (which is probably evidence the default cables are too thin to begin with), and they slid in easily.
    I closed the locking tabs, put everything back together, and it's been a month without any back massages or failures of any kind.
  10. thierryb
    1,379
    292
    Thanks.
    Where are the locking tabs ?
    How you open them ?
    Can you do detailed photos ?
