    29.8%
    54.8%
    0 vote(s)
    0.0%
    6.0%
    9.5%
  1. runout_mick
    runout_mick Pen Pal - Newbie
    Purchased in Sept 2014 from Memory Express for $230cdn. They seem to have stopped carrying them now, otherwise I'd have linked.
  2. music_ismath
    music_ismath Pen Pal - Newbie
    just chiming in to say thanks. I hadn't used my AVN8 (purchased Aug 2014) for a couple months and was dismayed that the pen had stopped working at some point once I came back to it. Was not eager to go through an RMA and stumbled across this thread. First just jiggled the cable a bit and it came back for a couple days before dying again. Then I reseated one end of the cable (cant remember which end) and it's been working great. Ordered the replacement cables and will probably replace once they come just to avoid future problems.
    I noticed a couple people mentioning having problems booting the device. I've noticed this too - sometimes it just doesn't want to turn on even though it's charged up. Eventually it does, although I'm not exactly sure what (if anything) I do to get it to go. Is this a known thing? Anything to be done about it?
    Overall I'm really impressed by this little guy.
    Mesosphere likes this.
  3. Kumabjorn
    4,309
    2,382
    If it has been off for a longer time and battery is run down, after charging it and turning it on it probably has a lot of Windows updates to install, this is done in the background and the device doesn't turn on until those updates are finished.
    fishdavis likes this.
  4. music_ismath
    Ah, that could be it. It was charged but yes, I believe there were updates. I've noticed it sometimes looks like it gets "stuck" during updates, where it sits forever on 0% waiting to download or install.
  5. greenblob
    greenblob Pen Pal - Newbie
    93
    Just bought one from woot.com and the pen didn't work out of the box. Installing the pen drivers from Asus' website didn't help. I'm still installing all the updates, so maybe things will get better, but it's not looking too great.
  6. WillAdams
    970
    414
    Mine lost its pen functionality after a slight fall --- opening the case, massaging the cable, and stopping and restarting the pen driver got it working again.
  7. Mesosphere
    5,277
    1,957
    My guess is the bulk of the returned units were returned for failed pens. Since the problem is intermittent at first, it might go unnoticed in the refurb process.
  8. greenblob
    93
    Well, it's working now, but we'll see if it craps out in a few days/weeks ...
  9. Mesosphere
    5,277
    1,957
    Yea, unfortunately that is the typical mode of failure. It rarely just suddenly dies for good. It just fails more and more frequently and becomes harder to get back. There have been exceptions though, so maybe you will get lucky =)
    I'd order the replacement cables now though if I were you.
  10. greenblob
    93
    Yup, it just failed (while I was using it, too!). Reinstalling the driver doesn't seem to help.
    EDIT: ... And it's back. I "massaged" the back where the cable should be and after restarting the driver it started working again. I have no idea if that actually did anything, but it means I can put off taking it apart.
  1. Luca92
    4,914
