    29.8%
    54.8%
    0 vote(s)
    0.0%
    6.0%
    9.5%
  1. Mesosphere
    5,277
    1,957
    Third, the length of time Bronsky has gone without experiencing the joy of a pen failure is amazing. Upon retirement his AVN8 should be put in a museum.
    fishdavis and Kumabjorn like this.
  2. Bronsky
    7,709
    4,168
    I'd rather be lucky than good.
    lovelaptops and fishdavis like this.
  3. Mesosphere
    5,277
    1,957
    Yea, I've had three successful cable replacement repairs across my two devices and one successful pre-emptive replacement. I didn't want to allow more than one vote per user though. Thought that might get confusing.
  4. WillAdams
    970
    414
    Well I managed to get the back cover off and tried massaging it, but no luck. Guess a Digikey order is in my future.
    But I tried again, this time disabling and re-enabling the Wacom digitizer in the Device Manager and that got it working.
    Thanks!
  5. Mesosphere
    5,277
    1,957
    Sometimes after a massage/reseat or replacement a reboot is required.
  6. thierryb
    1,380
    291
    I finally decided to do it on my first M80TA dated from 01/14 and which was probably one of the first to have the issue. My second M80TA has no issue since I got it.
    And after replacement, and few reboots, the pen is working.
    Thank you Meso for this solution.
    I should vote twice:
    I decided to vote that "Replacing the cable worked."
  7. Mesosphere
    5,277
    1,957
    That's the right vote. The point of this was to give new people an idea of the effectiveness of the fix. If I had it to do over again I'd eliminate options 3 and 5. I only added them to make the possible responses "complete". But really it just confuses the polls purpose.
    Option 5 in particular is not scientific at all considering, many more people with pen problems are likely to visit this thread than those that don't.
  8. epicfoxes
    epicfoxes Pen Pal - Newbie
    24
    I haven't votes yet. Massaging worked however I'm going to replace the cables once received from digi key
  9. runout_mick
    runout_mick Pen Pal - Newbie
    Bought 2 tablets at the same time about 6 months ago. Tablet one is still going strong, tablet two is fully functional again with replacement digikey cables. Easy fix, didn't bother massaging original cables.
    I bought 2 of each cable when the digitizer went on the first unit, just so I have them when the other fails (which seems inevitable).
    I don't mind though, I suspect it's why I got such an incredible deal on the machines in the first place. I bought them knowing about the problem and the fix.
  10. lovelaptops
    2,431
    876
    Mind mentioning where/when/cost you purchased at? Thanks, Jeff
  1. Luca92
    4,914
