    31.0%
    52.9%
    0 vote(s)
    0.0%
    6.9%
    9.2%
  1. spinedoc77
    1,871
    464
  2. Mesosphere
    5,313
    2,060
    Yea, I wish they would have at least linked here. There is info in this thread missing in their article. /shrug
  3. Kumabjorn
    4,360
    2,521
    I bet they'd get their knickers all tangled up if you used their material without acknowledging contribution.
  4. Mesosphere
    5,313
    2,060
    1 month since I straightened out and reseated my touch cable and not a single blip yet! It was failing about every other time I woke it from sleep before.
    It has been 10 days since I replaced the (perfectly functional) touch cable in my other unit. That is still working too, so it definitely seems like the replacement cable is compatible for those whose cable is to far gone for the massage approach.
  5. iad-artwork
    iad-artwork Pen Pal - Newbie
    35
    Another fix here!
    Thanks a lot
    Mesosphere likes this.
  6. Mesosphere
    5,313
    2,060
    Glad to help.
    Did you attempt to straighten out the cable at all or did you just reseat it? Either way, keep us up to date on how long it continues to work if you can.
    iad-artwork likes this.
  7. iad-artwork
    35
    Actually I did both, I reseat it from both ends, and straightened it.
    Sure I'll keep you up to date with its state.
    Thanks
  8. Mesosphere
    5,313
    2,060
    Thanks.
    I was kind of hoping you had only reseated because then we could track how effective that approach is =)
    The important thing is it is working though. Good luck.
  9. iad-artwork
    35
    Yes I'm glad it's working . But you know as the cable is really taller than necessary there's noway to make it straight, so I just tried to modify its curves.
  10. Mesosphere
    5,313
    2,060
    Yea, that is pretty much what we all did, but so far it seems to work.
  1. JoeS
    198
  2. Mr. Boosh
    1,177
  3. daddyfish
    567
