Display Problem
Discussion in 'Asus (Android)' started by MaxPower, Oct 12, 2012.
  1. MaxPower
    MaxPower Pen Pal - Newbie
    14
    Hello everyone,
    i have bought a couple of days ago a EA800. It´s a fantastic device.
    But i think, i have a problem. The right side (especially down right corner) of the display doesnt respond as sensitive as the left side, so i have to press harder. Also i noticed, that i cant write till the end at the right side. Ive calibrate the pen a couple of times, but no difference.
    Do you have any tips how i can solve that problem?
    THX:)
    PS: Sorry for my bad english
  2. eddy
    eddy Pen Pal - Newbie
    50
  3. BlacKnight
    184
    Sometimes this is related to the way you hold the pen. Specifically the tilt angle. The transceiver in the pen is located a few mm above the tip. If you are right handed and you tilt the pen while you write, then the transceiver will pass beyond the right edge of the screen before the pen tip reaches the edge of the screen.
    As a test you can try holding the pen vertical and see if you can make marks up to the edge of the screen. If this doesn't work then try recalibrating the screen while holding the pen vertical.
  4. MaxPower
    14
    Thank you for the tips
    The tweak and the recalibration have solved the problem.
    It´s so strange, in my university all that ipad and galaxy tab guys and girls look at me like they saw a UFO:D
