differences between active stylus A00, A01(Jan), A01(Feb)
Discussion in 'Dell' started by bugelrex, Mar 12, 2014.
  1. bugelrex
    260
    44
    I have the pleasure of having all 3 versions at once and can compare at the same time. Heres a summary
    with OneNote 2010 desktop and pressure sensitivity turned OFF
    A00: Mine worked well, other than battery drain and random hover click 2-4 times a day
    A01(Jan build date): Works well, but still experienced battery drain in 1 week. I get a hover click maybe once every few days.
    A01(Feb build date): needs more pressure to write consistently, If I don't apply slightly more pressure, sometimes strokes will not be recognized (if I write a whole page of words, about 5-10 words will have problems with writing). Replaced battery to confirm its not battery. If battery doesn't drain, I will just have to live with this. I will give up
    larsenmm likes this.
  2. St. Lamar
    St. Lamar Scribbler - Standard Member
    164
    Thanks for reporting in! Where do you actually find the manufacturing date? Is it on the packaging or the device?
  3. Ravynmagi
    Ravynmagi Scribbler - Standard Member
    178
    I wasn't sure either. I was looking on and inside the pen. But when you mentioned the packaging, I took a look. And that is where it's at. On the back of the packaging is a barcoded sticker and mine shows "Rev A01" "Mfg Date: Feb 2014".
  4. St. Lamar
    164
    Thanks, Ravy! I'm expecting mine any day now.
  5. sitongia
    sitongia Scribbler - Standard Member
    178
    29
    Just thought I'd mention that I have A00, bought with the bundle when the V8P was first announced, and I have yet to replace the battery. I only use the device every few days, but at least it's idle lifetime is good.
  6. dwx
    dwx Scribbler - Standard Member
    190
    24
    I have been using the A01 for a few weeks and the battery is fine. A00 writes better but has terrible battery life.
