Did your TM2 have hardware problems?
Discussion in 'HP TouchSmart TM2 (Wacom)' started by Malangyar, Mar 7, 2010.
Did you return your TM2?
  1. Yes, my TM2 had hardware problem(s) and I've returned more than one unit
    13 vote(s)
    8.1%
  2. Yes, my TM2 had hardware problem(s) and I've returned it
    45 vote(s)
    28.1%
  3. Yes, my TM2 had hardware problem(s) but I have not returned it
    35 vote(s)
    21.9%
  4. No, my TM2 is working correctly.
    66 vote(s)
    41.3%
  1. koao
    koao tm2's great.
    132
    I returned mine.
    (1) ATI GPU caused the i5 CPU to go high in temps, but that was not the only sole problem. That problem could have been fixed with a cooling pad.
    (2) I had a hinge problem, where in tablet mode, I can still press down on the laptop (it's like a door that won't close)
    (3) When I first turned it on, i pinched the side of the laptop (above the screen orientation button), and the graphics went all haywire and caused the system to freeze up. On several occasions this happened.
    The rest was like, I didn't like how glossy it was, all my fingerprints was smearing it, and it was so reflective in my room too...
  2. TRICH911
    TRICH911 Pen Pal - Newbie
    49
    I returned for a dead left speaker and a gap in the front of the lid. My replacement has no issues, hardware or software. I was satisfied in the manner in which HP handled as well.
  3. shadowyani
    shadowyani Pen Pal - Newbie
    73
    I finally got 3 with near perfect build quality after sending back 6! The only complaint is that one runs louder than the other 2. Temperature wise the i5 gets around 70 C when gaming. 50C when idle. That's on all 3 of them, so I assume its normal. I read somewhere the max temperature is 105 C.
  4. Joswea
    Joswea Pen Pal - Newbie
    44
    I find that a little hard to believe.. 105 C is insanely hot. Where'd you read that?
    Congrats, btw, on finally getting some good units. =]
  5. darthhen
    darthhen Scribbler - Standard Member
    226
    I received mine last week. It was a custom build model. I got it with i3 CPU & AMD graphics, no Bluetooth.
    It is working fine. I replaced the HDD with an Intel 80 GB SSD, with a fresh installation of Windows 7 Professional.
    Overall, I am very satisfied with this unit. I hope it can last at least 3 years before my next replacement. :D
  6. Ultimoose
    Ultimoose Scribbler - Standard Member
    103
    105C is the i5's rated max threshold per Intel.
  7. castnorth
    castnorth TM-2050us - Newbie
    purchased a tm2050-us from Frys over labor day and am all seems good except my MY dedicated rotation button the side of the screen has stopped working (any ideas-still in process of searching this great site).
    and the when i turn it to tablet mode it never seems to feel like the back of the monitor is set firmly on the keyboard. is this a common thing? I just keep having this feeling that their is something slightly off with my monitor build so i will wait a little before answering the poll. (-;
  8. Seketh
    Seketh Moderator Moderator
    758
    I think a user called "wakeupneo" had the same issue when he did a fresh Windows 7 install on his Core i5. Try searching his posts about the issue.
    I think his problem had something to do with the Quick Launch drivers. He installed them, but they wouldn't work. It's necessary to install another driver package from HP for them to work, I don't know which one though, sorry.
    The monitor wobbles a little bit if I force it, I think it's normal.
    On a side note, I would like to reset this pool, as it is a bit reduntant since it doesn't tell you if it's a 1st or 2nd generation tm2.
    I think that the new Core i3/i5 models are generally less problematic. I stopped seeing threads about serious hardware issues´, and the ones that ocasionally pop up are about Core 2 Duo tm2. I personally had three problematic C2D tm2 and a perfectly fine Core i3.
  9. koao
    koao tm2's great.
    132
    That happened to me, and I also bought a 2050us on frys over labor day.
    All I did was reinstall the Quick Launch applications. Apparently, the rotation button relies HEAVILY on HP Quick Launch buttons... i thought it wouldn't be necessary.
  10. castnorth
    Yea, I read a little more and saw that others had had a similar problem. I am glad to know that it is most likely a driver issue as i have loaded tm2 control and i am so happy. I don't know why hp would not have included something like this out of the box.
    "The monitor wobbles a little bit if I force it, I think it's normal."
    Good to know, I really like the tablet and I am already starting to use it heavily and it would suck if i had to return it and wait.
    "That happened to me, and I also bought a 2050us on frys over labor day."
    Koao, I saw another of your posts apout WEI and was curious how you got your gaming index so high. Any pointers?
    Thanks for your responses
