Did your TM2 have hardware problems?
Discussion in 'HP TouchSmart TM2 (Wacom)' started by Malangyar, Mar 7, 2010.
Did you return your TM2?
  1. Yes, my TM2 had hardware problem(s) and I've returned more than one unit
    13 vote(s)
    8.1%
  2. Yes, my TM2 had hardware problem(s) and I've returned it
    45 vote(s)
    28.1%
  3. Yes, my TM2 had hardware problem(s) but I have not returned it
    35 vote(s)
    21.9%
  4. No, my TM2 is working correctly.
    66 vote(s)
    41.3%
  1. e-schreiber
    2,629
    59
    Oh, dude! That sucks! Now I feel your pain. You did the right thing.
    I hope you enjoy your next tablet.
  2. Fkn0wned
    Fkn0wned Pen Pal - Newbie
    I am wondering if i should attempt to send my tm2 back to get it repaired, i am pretty sure the only problem i have at the moment, that i have noticed that is, but i have the keyboard not being seated at the top left i mean it is not a BIG issue but i don't really like seeing it or hearing the difference while typing.
    maybe this can be fixed by myself easily but i was wondering what you would do?
  3. jonny4
    jonny4 Pen Pal - Newbie
    43
    I am having an issue where the Touch stops responding for a bit but it seems like a software issue. I have chatted with HP once and I am updating all pertinent software now and will chat with them again afterward.
  4. e-schreiber
    2,629
    59
    It seems that touch goes into Standby when not used for a few minutes. And to wake it up, you need to touch the screen a few tines and wait a couple of seconds. At least that's the impression I get with my TM2.
  5. JoKu
    JoKu Pen Pal - Newbie
    ^^This is my problem as well after a lagged out system update of SP1 for Win7
    Doesn't seem like a button is stuck , but it acts like it.
  6. siyahbalik
    siyahbalik Pen Pal - Newbie
    i have a fan problem too. when i start tm2, fan work with fast speed (noisy). but sometimes notebook start normally (%20).
    When fan is working noisy, i look at the device manager and see "intel management engine interface" with yellow sign. i want to reinstall driver but pc said i allready newest driver. so i still waiting to fix it.
    EDIT: this problem appeared when install windows to an SSD, when original hdd is installed everything worked fine. so icant use SSD with TM2.
  7. spacegravity4me
    spacegravity4me Pen Pal - Newbie
    Man, after reading this thread I am freaking out! lol. I just got my tm2 in the mail last night. I set it up and one of the first things I noticed was that the mouse seemed unresponsive at times on the touchscreen. I didn't think too much of it until I started using the touch pad and it would go spastic frequently. It makes it difficult to play minecraft I can tell you that much. I had read nothing but positive reviews of this machine and I was really excited to get it. My last laptop was a tx2000 and needless to say it didn't end well. Motherboard over heated and gpu fried twice. SO, should I just send this thing back now or what? I really like it but the main reason I bought it was for its touch capability and if it is always going to give me probs then I don't know. It's slightly difficult to use it right now. I love the idea of this machine but I'm not attached to it yet. Let me know if I should just send it back or if there is something I can do. thanks.
  8. e-schreiber
    2,629
    59
    Things to try:
    1. Perform all updates and reboot.
    2. Re-install the touch drivers and reboot.
    3. Perform a Full System Recovery.
    4. Perform a Minimized Image Recovery (search the forum).
    5. Call HP Support.
    The device is a great bang the the buck, especially if you get it on sale! Do not give up on it until you've tried to fix it.
  9. Guppeh
    Guppeh Pen Pal - Newbie
    I had an battery problem with my TM2T-2200 CTO, where the battery would not charge until fully depleted (down to around 4-6%), at which point it would begin charging again, up to full.
    HP Diagnostic software said battery check was OK. Tech support had me re-install the drivers, run through battery calibration (basically, just let the notebook run on battery from 100% down without suspending or running on AC power at any point) -- only temporarily fixed the problem, it kept re-occuring. Also tried swapping in a new battery, problem kept re-occuring after that too. The problem was eventually resolved by sending it in for a motherboard swap.
    My notebook has also had the common no-touchscreen / USB not recognized glitch, which was fixed by following the excellent cable-reseating instructions in this forum. It just seems like these units have a lot of reliability issues.
