Device needed for artist/student
Discussion in 'What Tablet PC Should I Buy?' started by Annathy, Aug 20, 2017.
  1. Annathy
    Annathy Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    Preferably $350-$450 USD, $500 if necessary
    Yes
    Thinking of Windows Surface, since iPad doesn't support computer programs like Photoshop
    • 7.1 to 10-inches
    • 10 to 13-inches
    United States
    Nope.
    3-4+
    Notetaking, email, drawing/graphic design, Netflix/Youtube, documents/spreadsheets
    I use Android/Microsoft generally
    Primarily Microsoft Office and Photoshop. Illustrative/art programs.
    Only very light and infrequent gaming
    Not necessarily
    Screen Specifics
    Nope
    Not much, but occasionally
    Yes, with pressure sensitivity. No preference
    Component Specifics
    Honestly, I'm not sure.
    Full-sized USB slots for sure. Don't need HDMI.
    Misc
    I'm about to start my freshman year of college and am looking for a good device that will last me as many of my college years as possible. Currently I'm looking at the Microsoft Surface 3, which seems to be the most affordable option that covers what I'm looking for. However, from the reviews that say it's laggy and has poor battery life, I'm not sure it will last me very long or be worth the investment. So I'm considering spending more and getting Microsoft Surface Pro 3 instead, or even the Pro 4 if I absolutely need to. I'm just not sure what what will be right for my needs.
    On the one hand, I don't need a high-end device for business or intense video editing, gaming, etc. So I really don't think I should need the 4 or higher. But on the other hand, like I said, I *do* need something that will serve as basic laptop and that will last.
    Thanks very much for any suggestions/tips!
  2. Shizaru
    Shizaru Scribbler - Standard Member
    554
    391
