Desktop background in vertical tablet mode
Discussion in 'Hewlett Packard' started by drshakawa, Jul 23, 2008.
  1. drshakawa
    drshakawa Pen Pal - Newbie
    53
    Is there a way to make it so that you're desktop background says horizontal or stretched even when you have your pc in a vertical tablet mode? I just don't like how half of my desktop is black when I have it in tablet mode.
    I mean without having the screen all stretched
    Thanks!
  2. DRTigerlilly
    7,596
    751
    301
    are you in vista or xp, there are options for both to stretch the screen.
    In vista when you are selecting the desktop background, there are three panels at the bottom, one for stretched, one for tiled & one for centered.
    In XP there are the same options but it is in words, not graphically displayed.
    Re not having it stretched if you're concerned about distorting the image, use higher resolution photo's for your desktop pictures.
    preferably where the length is larger than 1280 pixels.
  3. R1C47
    R1C47 Scribbler - Standard Member
    148
    It would be awesome if one could set wallpapers for each rotation state though.
    Because not all the wallpapers I like are 1280 x 1280 or more and the important part of the picture isn't always at the center.
    Do any of you know of any software that can do this?(different WP for each different rotation)
  4. BerkleyJ
    BerkleyJ Pen Pal - Newbie
    83
  5. R1C47
    148
    It works, incredibly AWESOME
    Great find BerkleyJ
    1 problem though, it doesn't accept pngs as wallpapers.
  6. drshakawa
    53
    awesome, thanks ya'll!
