dell xt screen flicker and laggy brightness changes
Discussion in 'Dell' started by alphakenny1, May 1, 2009.
  1. darkdss
    darkdss Pen Pal - Newbie
    Quick questions for fellow XT owners:
    1. Sometimes when I adjust my brightness to the lower levels, the screen flickers a bit. It's not an on/off flicker, rather it seems like its having trouble keeping the brightness at that level (it will flicker between subltle lower and higher brightness settings.) Is this normal?
    2. When you hit FN + ArrowKeyUp or ArrowKeyDown (ie. brightness changing), is there a slight lag delay between each switch?
  2. minaximal
    minaximal xt user
    nope, thats two problems i don't have, maybe your connections are loose or a problem with the graphics?
    although i am worrieed about the flimsey hinge and wobbly screen oneday falling off.
  3. alphakenny1
    alphakenny1 Pen Pal - Newbie
    48
    i'm not too familiar with the xt tablets but i used E6400 with LED backlighting and it was a common problem for the screen to flicker. I wasn't too sure what can be done. I just remember people saying that there wasn't much that can be done and it was normal due to some power settings on vista.
