Dell Venue 8 and 11 Pro
Discussion in 'Dell' started by excalibur1814, Oct 2, 2013.
  1. Zeelobby
    Zeelobby Scribbler - Standard Member Senior Member
    1,229
    199
    Except this synaptic pen has pressure sensitivity and palm rejection. Its definitely more advanced than the adonit. there has to be more underlying tech.
    Sent from my Galaxy Nexus using Tapatalk 4
  2. Avenger
    Avenger Scribbler - Standard Member
    115
    Yes it is more advanced, but I think it is the same technology. Even Adonit has said that it's next stylus, using the same technology will have pressure sensitivity and palm rejection. It is the one that Adobe has been showing (previewing) for the iPad. They are going to sell it under their name but Adonit is making it using this technology. I think synaptics is just bringing the whole package to the market faster.
  3. bloodycape
    bloodycape Scribbler - Standard Member Senior Member
    2,141
    127
    I think some of the current Adonit pen use BT to connect to get pen support, but it doesn't offer full pressure sensitivity, and I think with these types of pens palm rejection is app dependent, no? I don't think that is how Synaptic's system works. I think it is more N-Trig like than anything.
  4. Mesosphere
    5,202
    1,859
    It doesn't have a separate digitizer layer for the pen, but it sounds like it has a capacitive layer that is made with pen input in mind. It has a higher resolution grid and increased sensitivity to sense the smaller capacitive changes induced by a hovering pen. The Adonit and other capacitive pens are taking a digitizer layer designed exclusively for touch and trying to make it work for a pen. This one sounds like it was designed for pen use, so I would think it is potentially much better than the hacks you see for "typical" capacitive screens.
    Still though as with any new tech it is smart to be skeptical. Particularly considering the track record of Wacom alternatives to date.
    Zeelobby likes this.
  5. Avenger
    115
    I hope it is like you say, and not a capacitive "hack" like I think it is. I would like to buy the 11" tablet.
  6. Mesosphere
    5,202
    1,859
    *Fingers crossed*. I want to give the 8" a try.
  7. sayonical
    sayonical Pen Pal - Newbie
    36
    Hi Guys. first post here!
    i went to the #dellvenue store in nyc and got to spend some time with the 8 inch dell venue. here are my thoughts
    Pros:
    thin and very light
    very bright and sharp screen :)
    windows 8 runs really snappy on this! compared to my surface rt the venue pro flies! apps opened quickly, navigating xbox music was very fast the new mail app opened instantly nice!
    Pen support! i got to play with the pen extensively!
    downloaded OneNote metro app . the pen supports palm rejection - i rested my palm on the glass and wrote. i am not used to writing on glass so it didnt feel natural but it worked. it wasnt perfect, i feel the wacom on the surface was much better but this is miles above the fat rubber pen i use on the Surface RT. the pen also supports hover, has buttons on it i think for lasso effect and erase...
    The cons
    boring design
    i hated the spiral contoured back design much prefer the smooth soft touch of the android version
    low res screen compared to the competition but thats ok because the screen is nice - good colors, viewing angles and sharpness. it shames the Acer W3! Also any higher resolution the desktop might be invisible! metro works fine on 8 inch and you can snap apps side by side even at this resolution!
    no HDMI port! how will i connect this to a larger monitor?
    Since i have a surface rt i missed the kickstand :) and the capacitive start button on the surface bezel. the venue have some weird placement of the start button with none on the bezels so you will have to adapt to using the charms menu exclusively
    any questions feel free to ask
    -Sayon
    Mesosphere, JoeS, MikeOx and 2 others like this.
  8. cardman827
    cardman827 Pen Pal - Newbie
    34
    Hello,
    Do you happen to know if the store would be open today Sunday. I can't find too much information for it online. It looks like it runs through the 18th of October but I don't want to go to Manhattan for nothing. I live in New Jersey, not too far but still do not want to make a wasted trip.
  9. lafester
    lafester Pen Pal - Newbie
    71
    So basic pen support looks pretty nice thanks for sharing!
    I'm pretty sure the venue display is open every day.
  10. III.Jg27ADLER
    III.Jg27ADLER Scribbler - Standard Member
    157
    Mhhh, I am not sure if the writing quality turns out to be comparable to the Atmel pens. So rather disappointing.
    Does anyone know about the Dell roadmap 2013 for tablets? So high are chances for a successor of the Dell Latitude 10? I am afraid, the Venue 10 seems to fill the gap for the business sector already though...damn, I want N-Trig or at least Wacom!
