Dell Venue 8 and 11 Pro
Discussion in 'Dell' started by excalibur1814, Oct 2, 2013.
  1. adz7777
    adz7777 Pen Pal - Newbie
    55
    i just did a test ....... (venue 11 pro atom model)
    i left it on sleep for 1 hour (no programmes open) and it lost 5% battery , that's too much isn't it??
  2. Mikerman
    1,293
    126
    It depends: it's a large amount, BUT if things were happening in the background--e.g. Windows updates--it's understandable. I would just keep an eye on it, over time, and see how it averages.
  3. adz7777
    55
    Windows updates was definately NOT running , nothing was , but yea i'll keep an eye on things , but at the moment the battery is draining too quick!
  4. Mikerman
    1,293
    126
    Hopefully, it'll stabilize . . . .
  5. adobepro
    adobepro Pen Pal - Newbie
    Does anyone know if there is an aftermarket cooler to replace the OEM CPU cooler in the 7130? My avg temp with nominal use at 73C ambient, measured by HWMON, is about 58C, playing a video can kick it up to 63C and then the fan kicks in loud. Looking at the dell video ( Venue11 Pro 7130 thermal fan disassembly video | Dell ) , it doesn't look like they really had any intention for passive cooling, so the chip seems to run hot relying on the fan to cool it. Even my M4400 Intel Penryn runs cooler, averaging 28C with a light load. I set the max CPU performance to 95% and even tried the XTU tool to undervolt it to around 4.42 volts and reduced the max clock speed to 560MHz and the fan still kicks in when playing back video.
  6. blackstar2
    blackstar2 Pen Pal - Newbie
    Hey Guys,
    i hope anyone can help me about my problem with the Dell Venue 8 Pro.
    I have the 32GB Version and I have a problem with the sound after i installed a Windows 8.1 update.
    The Sound is really low , I realyze that when I use the Virtual Keyboard from Windows. The Click sound from that is really low after the update, before it was much louder.
    I would be very grateful if someone could help me.
    thanks
  7. PrznMovieFan
    PrznMovieFan Pen Pal - Newbie
    63
  8. PrznMovieFan
    63
  9. PeterMac
    PeterMac Pen Pal - Newbie
    I have a question is it normal in Venue 8 Pro that two cores #2,3 even at idle work always at 1333MHz ?
    Here is screen from HWInfo
    Also as you can see Turbo mode with 1833MHz clock is only work on #0,1 cores.
    Please could someone check this also and confirm ?
