Dell Venue 8 and 11 Pro
Discussion in 'Dell' started by excalibur1814, Oct 2, 2013.
  1. critical_
    critical_ Pen Pal - Newbie
    34
    I've done it. More information at this post:
    http://forum.tabletpcreview.com/del...re-i-version-owners-lounge-30.html#post390322
    The WWAN cards you listed aren't in the correct form-factor for the slot. My post lists the 2 that will work.
    It's a micro-SIM slot. It works.
  2. thepinkpanter
    thepinkpanter Pen Pal - Newbie
    36
    Hello ,
    I would like to buy the same configuration , and I need to know if you did upgrade your Venue 11 ,
    what model number is your Venue 11?
    thanks in advance for your help.
  3. botudi
    botudi Pen Pal - Newbie
    hi there,
    just bought a 11'' european i3 config, with 3g support and I'm a bit puzzled : does it have GPS or not ?!
    I mean not a software, but the module that will enable me, with the right software, to use the tablet for GPS navigation......
    info on this seems a bit confusing :/
  4. Lanurd
    Lanurd Pen Pal - Newbie
    Without any research at all I believe the GPS would have to be a function of an add-on 3G/4G module. Research the 3G mobile adapter you have installed.
    All my 11" i5 vPro has is an antenna with empty connections and the closest thing to GPS is my "Windows Location".
  5. botudi
    I just ordered it...haven't got it yet....but this seems a bit off not to have gps.
    On some sites it says it has on others it's a blur.
    Anyone who has a european i3 pro 11 could confirm this or not ?
  6. botudi
    still haven't got it yet, but I go confirmation from Dell that the SM04TV11P9JGERMB has the gps (in case anyone else gets here with the dilemma ) .....so it should work great with here maps.
    the only question remains if the targus rugged case will cover the air vents of the iCore versions of the venue 11 tablets and by covering them might do some damage while using the tablet for basic tasks on the go,
  7. adz7777
    adz7777 Pen Pal - Newbie
    55
    Just received mine venue 11 pro (atom version) .....
    i have 2 problems....
    The battery only lasted 6 hours from 100% to 1% , screen brightness was on lowest setting aswell! something is eating my battery , iv'e deleted some bloatware , i thought i would get between 8-10 hours!
    also when i press the volume button on the left side of the tablet it crashes and i have to hold power button to turn it off!
    any tips for the battery?
  8. FZelle
    781
    193
    Before doing something, do a complete restore from the recovery and then install all updates.
    It might also be that you have automatic updates on, and the tablet has installed updates in the background.
    I always switch it to check for updates and notify, but not install it self ( don't know the English description ).
  9. adz7777
    55
    automatic updates were on , iv'e now turned them off to notify.
    i dont know if this will make a difference to battery life , i hope so...
  10. Mikerman
    1,289
    123
    Likely so, especially on Patch Tuesdays when there are mega-updates.
