Dell venue 11 Pro i5 overclockED !
Discussion in 'Dell' started by Martin Demin, Jan 2, 2015.
  1. avs.andrew
    avs.andrew Pen Pal - Newbie
    How can I get IFR.txt for A13 7130? I can't wait to try it out.
  2. Martin Demin
    Martin Demin Pen Pal - Newbie
    I think that as long as you have it plugged in, it works.
    Chrischi1988 likes this.
  3. mxmxmx
    mxmxmx Pen Pal - Newbie
    what about the solution to 7130 with i3 ?
    to try ?
  4. PhytochromeFr
    PhytochromeFr Pen Pal - Newbie
    19
    WOW! it works very well on DVP11 7130 vpro(i5 4300y) too! thanks!
      File size:
      77.4 KB
      404
  5. Martin Demin
  6. mxmxmx
    please to write manual step by step ) please
    I am very so so in fix hardware ) I have i3-4020Y
    in
    0xfed159a0
    I see
    00DD8030
  7. avs.andrew
    Ok. So I've extracted IFR file for A13 7130 bios file. It seems it has same vars addresses. I did the changes from mods.txt (only the ones marked with *). Rebooted - didn't see any changes (not even removal of my personally hated 67 degrees temperature throttling). Afterwards did the memory address edit with bar-edit, and it worked! Partially. The temperature throttling is gone. But I didn't manage to see any effect of changing the turbo boost power max watts. I set it to 11w or 14w. I see a spike in performance for a second and then it's back to usual. ThrottleStop shows real tdp at 6W. Anyway even if TDP control doesn't work out - I am thankful for ability to get rid of thermal throttling!
  8. PhytochromeFr
    19
    it maybe cause of 7130 MS have Connected Standby. it have low power S0 idle function and so it doesn't enter S1-S3 state(normal sleep mode). that makes last step doesn't works.
  9. Martin Demin
    Did you put the tablet to sleep after rewriting the memory address to 0x0000000 ? Is your battery meter showing "NOT charging" ?
    After waking up it will show something like"0x00DC000".
  10. avs.andrew
    I did put to sleep the tablet with power button for 3-4 seconds. I didn't look at the battery icon, because the AC charger was 10 meters away from me. I would have to try again the process of memory reset with bar-edit and check afterwards the battery meter and memory value for the address. Thanks.
