Dell Venue 11 Pro 7140 (Late 2014)
Discussion in 'Dell' started by jamesstringer, Nov 2, 2014.
  1. rushmore69
    rushmore69 Scribbler - Standard Member
    219
    23
    Ruh roh! Are you saying then mine is defective ;) I updated to version 3 bios and had to then go into the bios to get the display to turn off when shutting the lid.
  2. Xer0
    Xer0 Pen Pal - Newbie
    88
    64 or 128GB?
  3. phlipat
    phlipat Pen Pal - Newbie
    128GB
    Xer0 likes this.
  4. III.Jg27ADLER
    III.Jg27ADLER Scribbler - Standard Member
    159
  5. gaidin43
    gaidin43 Pen Pal - Newbie
    88
    I'd be interested to know if the 7140 is coming out with this as did the older model with I core processors did.
    Also if anyone gets any luck with finding the LTE version let us know.
  6. phlipat
    Looking at the Quick Start Guide, the SIM reader (and presumably the antennas) will only be found on the models specifically designated as being for LTE. These don't appear to be available in the US yet.
  7. Xer0
    88
    can someone export and upload me the stock power plans?
    i did a clean Win 10 install due to the Recovery Medium made by Dell's Software not working
    now missing the power plans and can not set different times for screen off and power saving
  8. rushmore69
    219
    23
    I am not aware of an option to turn the display off, but leave the device on. At least have not found it like on a laptop or desktop.
  9. Xer0
    88
    it's an usual option or laptop
    here its only avaiable in advanced settings but what you set there is just copied to the power save times
  10. jackfrost
    jackfrost Pen Pal - Newbie
    Mine (and I'm guessing most people's) comes with the SIM reader, its just blocked by a solid plastic cover (the solid plastic next to the micro sd card).
    I've already modified mine to allow SIM insertion/removal and installed a 5808e and antennas... wwan works great.
    Modifying it to allow the SIM card is a destructive process though, you have to carve/file out the slot in the solid plastic.
