Current 2730p and Win7 battery life?
Discussion in 'HP Elitebooks' started by rjh, Jul 20, 2010.
  1. rjh
    rjh Pen Pal - Newbie
    Around the end of 2009 and early 2010, there were quite a lot of reports that installing Windows 7 on the 2730p resulted in poor battery life.
    Is this still the case, or have updated drivers from HP/updates from MS fixed the issue? Is it still affecting anybody?
    TIA
  2. dceggert
    3,094
    532
    Still the same issue here for me. I just have not had the time to figure it out yet. It is easy to clip on the slice battery when needed and then charge the whole combo when I can.
    Do I like 50% battery life? No, I don't, but due to the time constraints I have no other alternative at the moment.
    Dan
  3. pwnsweet
    pwnsweet Pen Pal - Newbie
    51
    What kind of lifetime are we talking about here? I'm on Win 7 and I get about 4-5hrs on a single charge with the regular battery.
  4. rjh
    My battery life is about 3-4 hours without the slice, and I haven't done anything to optimise power savings. SL9400 (1.86 C2D processor), 2GB RAM, 120GB (spinning) drive. Windows XP.
    Seriously considering fitting an SSD, and wondering if it is worth upgrading to Win 7 at the same time, but poor battery life might be an issue.
  5. thegerg
    thegerg Pen Pal - Newbie
    Getting half battery life on my 2710p on windows 7 ultimate 64bit :(
  6. sfdoddsy
    sfdoddsy Pen Pal - Newbie
    37
    I'm getting 5 hours from Win 7 Ultimate.
  7. rjh
    What hardware configuration?
  8. rjh
    What do you consider half battery life - around 2 hours?
  9. nrf1re
    nrf1re Pen Pal - Newbie
    Upgraded (fresh install) from XP to Win7 64.
    Battery life is terrible.
    Considering changing to Win7 32bit and sees if that is any better. Dont have the time. Been using the slice more often, little exra weight but no time to muck around and fix this. Dont want to go back to XP either!
  10. organic
    organic Pen Pal - Newbie
    53
    To find the reason for poor battery life you'll need to post the consumption in WATT. Important is also to describe what usage you have. Web Surfing or E-Mail or Videos...
    Next point is: there are different primary batteries out there, for example 39WH or 44WH or 51WH
    to get the energy consumption BatteryMon (trail version for 30days free) could be the first choice or Everest ultimate
    Next point: how old is the battery?
    Cheers
