Cube Mix Plus (Kaby Lake) tablet review
Discussion in 'Other Brands' started by surfaceproartist, Jan 9, 2017.
  1. FZelle
    771
    184
    @Mich84 :
    As I said, I only switched it on, nothing else was changed.
    I have read somewhere that sometimes the usb-c plugs itself are not working in one direction, have you tried to use it the other way?
    Is it in completely?
  2. Mich84
    Mich84 Pen Pal - Newbie
    Solved!!! I bought a new cable and works properly without touch anything!!!
    Thank you for your support!!!!
  3. Rachel Yun
    Rachel Yun Pen Pal - Newbie
    Hello. How can I disable touchpad gestures?
  4. jhoff80
    jhoff80 Scribbler - Standard Member Senior Member
    3,289
    993
    Unfortunately, you can't, assuming it's like the previous i7 Book. Basically, the touchpad reports to the PC as a mouse instead of a touchpad.
  5. Rachel Yun
    Hi. What stylus is compatible with Cube Mix Plus? CEP01 or CEP02? Maybe any Wacom EMR compatible?
  6. jhoff80
    3,289
    993
    As it turns out, there IS a way to disable touchpad gestures by tweaking the script in the post below. It says it's for the i9 but it works for my i7 Book and I am pretty sure the same would also work for the Mix Plus:
    https://forum.xda-developers.com/showpost.php?p=69722888&postcount=380
    Now if only it could disable tap to click...
    Edit: Attached my modified version.
  7. Celpacius
    Celpacius Pen Pal - Newbie
    23
    looking to buy something like this but on amazon. is there something comparable in specs for around the same price?
  8. FZelle
    771
    184
  9. okieiam
    okieiam Scribbler - Standard Member
    210
    have tried to install Linux .
    These things will not work
    + Camera
    + Windows button
  10. okieiam
    210
