Cube Mix Plus (Kaby Lake) tablet review
Discussion in 'Other Brands' started by surfaceproartist, Jan 9, 2017.
  1. surfaceproartist
    2,946
    1,847
    Tell me about it. Mine got scratched on the first day. Let me know if you're able to replace yours. I'm pretty timid when it comes to modifying my tablets.
  2. dellaster
    dellaster Scribbler - Standard Member Senior Member
    745
    546
    I didn't buy one of these so I can't tell you. Good luck to you if you try it! :thumbsup:
  3. FZelle
    702
    98
    Just because @surfaceproartist doesn't want to risk it, doesn't mean it's not meant to be replaced.
    Just don't use sharp things to remove it.
    My tempered glass is on the way from china, so I can tell you in a few weeks if it works.
    dellaster and surfaceproartist like this.
  4. okieiam
    okieiam Scribbler - Standard Member
    207
    55
    Because it is quite god dam good no one dare to touch it
  5. andrewmoeljono
    andrewmoeljono Pen Pal - Newbie
    Hi guys, I just received the Wacom Pen. I am just wondering about your experiences when using the pen. For me, I need to press quite hard on the on screen keyboard when typing using the pen. When drawing or writing text on the windows ink, I need to position the pen about 90 degrees to be able to write. Also to open an application, I need to kind of pressing the icon with the pen, if I just lightly touch it, it won't response (application wont open). Is this normal behavior of the pen? The type that I bought is "Active Stylus Pen for Cube iWork 11 / i7 Book / i7 ". Thanks for the information.
  6. okieiam
    207
    55
    I order it complete it with dock and pen
    All shy new no any scratch or dust on it
    Airline freight sprayed on it
    I receive it two day ago from that local retailer.
    He open the seal to check it before calling me
    For the pen, work well with Photo Shop and ArtRage
    Pressure quite good,
    If you use it as a mouse, you have to hard click the pen to kick in as a click, that is software feature. clearly enough
  7. andrewmoeljono
    Hi, may I know the type of the pen that you bought? I bought the one from gearbest. I have to pressed it really hard to use the pen unlike the YouTube video from teachable when using Wacom pen on cube mix. Thanks for the info
  8. okieiam
    207
    55
    I don'ts known, the pen has no name, has eraser, inking great to click and double click you have to luck the pen to the surface, sound like click-click
    image of the pen taken by the tablet camera itself and using a on screen keyboard input handwriting with palm rest
    quite satisfactory
    sonichedgehog360 likes this.
  9. andrewmoeljono
    Thanks
  10. okieiam
    207
    55
