Cube i7 Book Wacom EMR tablet review
Discussion in 'Other Brands' started by surfaceproartist, Sep 11, 2016.
  1. surfaceproartist
    2,946
    1,847
    Kritter and Marty like this.
  2. ATIVQ
    ATIVQ V⅁O⅄ Senior Member
    901
    477
    Edge drift?
  3. surfaceproartist
    2,946
    1,847
    None that I've noticed. It's the best calibrated EMR tablet I can remember out of the box. But of course that's no guarantee that they're all that way.
    WillAdams and ATIVQ like this.
  4. Kritter
    Kritter Pen Pal - Newbie
    71
    Another great review! I'm still crossing my fingers for Mytrix to make a US-rebranding of the i7 book.
    surfaceproartist likes this.
  5. asdfrozen
    asdfrozen Pen Pal - Newbie
    14
    The micro SD card slot on mine doesn't seem to work as well.
  6. jhoff80
    jhoff80 Scribbler - Standard Member Senior Member
    3,136
    833
    Yeah, I agree with you so much on the power button 5 seconds thing. Really annoying.
    I would assume that the microSD thing is a quality control issue and not software, mine has worked fine the entire time. You might also want to explore the UEFI options because there are quite a few for the SD card in there.
    Also, which category is the Chinese driver under? I reinstalled and re-set up everything from scratch (using a combination of generic Intel drivers and the backup I had made of the Book's original driver folder) so I might be able to potentially help you out.
