Cube i7 Book, keyboard dock - Ctrl+Shift+Alt doesn't work?
Discussion in 'Other Brands' started by acoccimi, Apr 7, 2017.
  1. acoccimi
    acoccimi Pen Pal - Newbie
    Hey, I recently bought a Cube i7 Book, and it's pretty good, but I'm wondering if anyone is encountering the same issues I am:
    -Using the keyboard dock, Ctrl+Shift does not work with the bottom row of letters, and Ctrl+Shift+Alt does not work at all. Other combinations that work on most other keyboards are similarly hit-or-miss on this one.
    -Occasionally, certain keys stay pressed (like Ctrl/Shift/Alt/Delete) and I have to restart the device.
    Is it a problem with my device, or is it an inherent design flaw? I'm debating whether or not to return the device or the keyboard.
  2. okieiam
    okieiam Scribbler - Standard Member
    210
    55
    my Mix Plus dock ok
  3. FZelle
    761
    168
    The only grievance I have is that on the german keyboard the <> keys are missing, they are physically not there.
  4. Rachel Yun
    Rachel Yun Pen Pal - Newbie
    Hello, how can I disable the Fn key on CDK09 keyboard?
