CS6 occasionally dropping pressure sensitivity then returning ???
Discussion in 'Artists' started by Steve B, Dec 10, 2013.
  1. T-ravisty
    T-ravisty Scribbler - Standard Member
    209
    92
    I did see this thread earlier and had meant to post but got side-tracked.
    Anyway, no I don't have these issues.
    I did when I first got my x230t but then changed the registry to inhibit it from happening along with disabling "Flicks" and the "Press and Hold for Right Click" features.
    Find attached a "penoff.zip" folder containing a registry file (265 bytes) attached, just run it and it'll stop the ripples in your programs but will keep the ripples on the desktop as Stoneseeker has - I also find I get the ripples when tapping in Google Chrome too.*
    I also get the pen not responding sometimes, to get around that I either turn the pen around to the eraser, lock the computer and login again or disable the Wacom service and then re-enable.
    I never use the eraser for erasing.
    Anyway, one odd quirk I get is the pen to register that I'm holding the left-click button and it draws in full opacity, but this very very rarely happens to me.
    Anyway, have a look at the .reg file and see if it helps.
    Also note that I'm also using CS6.
    *It has worked for me, but I won't be responsible if it damages your system - Open it in Notepad before running if you want to check it.
  2. dream3
    322
    14
    What are these ripples and water drop you guys are talking about?
  3. T-ravisty
    209
    92
    I just had to reinstall Win 7 64-bit as I was playing with System 32 for other workarounds and I broke something, all good though.
    Anyway, I had to do all of this again to get rid of the ripples.
    I was looking through my bookmarks when I found this from a long time ago; after changing accordingly everything worked fine.
    @dream3: these ripples.
  4. dream3
    322
    14
    Hmm that's weird. I remember having those a long time ago, just briefly. And they did go away by disabling a couple of options, yes. But nothing too complicated or too deep into the system. Just regular checkboxes.
    The ones I can remember in win7 are: disabling windows ink, disabling flicks, disabling press-hold for right-click, disabling tabletpc features, in windows features.
    Guess that was it basically. Though I'm 100% positive I did not have to go to registry or administrative stuff to solve that.
    Now what is the water drop thing, if I may ask?
  5. stoneseeker
    3,334
    779
    That was what got rid of it in your list of things to run off.
    But not everyone wants to lose auto-rotate and the onscreen keyboard, so the other workaround I listed allows you to keep those while getting rid of the "ripple pen feedback"
  6. dream3
    322
    14
    Ahh got it. I never used windows 7 with tablets and with windows 8 there are no ripples at all. Maybe they've fixed it.
  7. dream3
    322
    14
    Okay, so ripples are definitely gone.
    How about the random lost of pressure sensitivity? I get that on my windows 8 surface, as well as using other wacom tablets on my windows 7 desktop.
    Any fixes for that already?
  8. okieiam
    okieiam Scribbler - Standard Member
    203
    53
    no news? it is
