Cracked my x220 tablet display
Discussion in 'Lenovo (IBM)' started by bonoz, Mar 14, 2012.
  1. bonoz
    bonoz Pen Pal - Newbie
    32
    Unfortunately I cracked my display. When I was closing the lid one of my ear phones was sitting on the keyboard on the side. It easily cracked/shattered the bottom right of the display. Thankfully the laptop is still operating, monitor is working. The touchscreen on the other hand is not. The touchscreen on the right half of the monitor is gone. Touchscreen on left is ok. But the pen is working all over which is great. Here's a picture:
    From the side:
    From the front:
    As you can see it's not so bad - I can 'live' with it. But just out of curiosity - is there anything I can do about it? get a replacement? warranty would probably not cover it, right? any chance of a free replacement? (I once sent a camera to this online place for a broken screen and they fixed it for free using my camera's warranty - not sure how that worked - but is there something I can do here like that?)
    Thanks
  2. ZaZ
    ZaZ Scribbler - Standard Member
    210
    Unless you got the accidental coverage, I'd say it's unlikely they'll fix it for free. Unfortunately, a repair by Lenovo, which is the only way to keep your warranty in tact, probably will cost as much as a new machine. That's too bad. Sorry to hear about your misfortune.
  3. bonoz
    32
    Thanks!
    Any chance I could purchase just the screen from somewhere and replace it myself? I am mechanically inclined.
  4. dceggert
    3,045
    508
    There are usually some new and used screens on eBay and sometimes whole machines for parts with something else scavenged. You may be able to find a replacement for $200 or less.
    Since it works for you in the meantime, take your time.
    Maybe someone else can chime in if they know but there are also some part outlets that have parts for Thinkpads on the net. I remember obtaining a snap on door for one of my laptops once.
  5. darthhen
    darthhen Scribbler - Standard Member
    226
    Ouch! Oh man...let us know your progress.
  6. fatpolomanjr
    fatpolomanjr Scribbler - Standard Member
    108
    I just asked a UK seller of a $115 "X220T LED screen" on ebay the following question:
    "This screen is for X220T, but does that mean it has an Active Digitizer and accepts Pen and/or Multitouch inputs? I believe X220T is the tablet version of the X220, but I can't tell if this screen has the tablet capabilities of the original X220T screen."
    Usually sellers for such screens sell the entire LCD assembly for $400+, so it seems the price is too good to be true.
  7. Hattori Hanzo
    614
    You're lucky in that your display is fine and just the front glass with the touch stuff is really damaged.
    I haven't seen the x220t's display out of its shell yet, but my guess would be the following:
    The digitizer is still an add on board behind the screen that is detachable via screws and/or tape, some glue. The actual panel will have the glass mounted via some translucent glue to it. I know several people failed to separate the glass from the actual panel for the x61t SXGA+ display.
    The touch screen should be a thing layer on the panel facing side of the glass.
    So if the seller offers just the panel with the glued on touch screen, you should be able to just switch over the digitizer on the backside. It's more work, but not paying for a second digitizer could be the reason for the lower price and is also a benefit ;)
  8. LROBBINS
    LROBBINS Scribbler - Standard Member
    120
    If you do get a complete screen assembly, do recall that Lenovo's maintenance manuals are available to all and the instructions for replacing the complete assembly will be very detailed. They will also get you partway through the job if you end up mounting a new screen in your old lid. I am a bit sensitive on this score as Fujitsu manuals are only available to their "authorized" service stations although Lenovo and HP actually encourage customers to swap FRU's themselves. My daughter now has a Fujitsu T5010 mounted on her wheelchair as her voice-output communications computer, and I'd much rather handle maintenance myself than leave her "gagged" for as long as it takes to get "authorized" service.
  9. fatpolomanjr
    108
    They replied: no touch screen. But it's a start I suppose.
  10. ZaZ
    210
    I don't think that exactly true, at least not in the case of Lenovo. I can't say for HP. FRUs are not considered user replaceable by Lenovo. Doing so will likely leave your warranty suspect. Now you could send it in and they might never know, but if they want to make an issue of it, they can.
