!!Cracked LCD Screen T4215!!
Discussion in 'Fujitsu' started by Rieuk, May 21, 2007.
  1. kpzze
    kpzze Pen Pal - Newbie
    I dropped my T4215 and cracked the lcd screen.
    I called Fujitsu and they wonna charge me a fee of 755.00
    Well since I spent all this money on the laptop I dont have the 755. Can any one telll me where I can buy a replacement screen?
    or atleast give me a part number....PLEASE!!!!!!!!!!!!!!!!
  2. Rieuk
    Rieuk Scribbler - Standard Member
    121
    What type of screen was it?
  3. yannick
    yannick Pen Pal - Newbie
    is the LCD really cracked or is it just the mask you write on that is cracked. I can imagine a screen costing $755 but a mask should set you back a max of $200
  4. kpzze
    the mask is okay. It's the lcd screen that is cracked
  5. Rieuk
    121
    Well if it was an XGA screen, then you might be able to purchase a T4010 or T4020 screen from screentekinc.com and try installing that. You'd probably need to do a bit of research to see if that is possible or not.
    But if it was an SXGA+ screen then I don't know. Unless you want to do an experiment and get a Toshiba M200 SXGA+ screen and see if you can get it in there :)
Similar Threads - Cracked Screen T4215
  1. Steve S
    734
