Corel Painter Issues with Surface Pro 7 Pen Pressure Sensitivity and Tilt
Discussion in 'Microsoft' started by Siavash Mortazavi, Dec 6, 2019.
  1. Siavash Mortazavi
    Siavash Mortazavi Pen Pal - Newbie
    Hi,
    I have Surface Pro 7 and all the drivers are up-to-date (Reinstalled them from here to make sure: https://www.microsoft.com/en-us/download/details.aspx?id=100419)
    Surface Pen pressure sensitivity does not work on Corel Painter 2018/19/20, and here are some observations:
    1. Pressure sensitivity works well all other Microsoft and non-Microsoft apps, including Corel Photo-paint!
    2. Setting Painter "Tablet Options" to "Wacom-compatible Device (Wintab)" results in neither pressure sensitivity, nor pen tilt detection.
    3. Setting Painter "Tablet Options" to "RTS-compatible device..." results in weird broken lines with no pressure or tilt detection.
    4. I Have installed wacom latest driver (honestly doesn't make sense to me, but was recommended on some other forums), and still it's not working...
    5. Painter works fine with my Wacom tablet, and also I have seen videos on Youtube that shows Painter is fine on Surface Pro 6, so what the heck is this problem?! A fellow on PainterFactory forum has replied with "Painter's troubles with Tablets & pen is abysmal" and I'm afraid that's true.
    I have tried all the obvious solutions, and none worked, and Corel tech support is not helpful at all! If you have any remedy, it'll be hugely appreciated.
    Thanks,
    Sia
  2. tampopo
    tampopo Pen Pal - Newbie
    I have exactly same issues with Surface Slim Pen and Surface Pro 7 on Corel Painter series. I thought that's the new Slim Pen's problem in the beginning and decide to exchange it to standard surface pen until I saw your post.
    So it could be the New surface pro 7 or Corel painter's problem. I hope it'll get update driver or software soon.
  3. Siavash Mortazavi
    I've posted this issue to a few forums and websites, and also submitted the issue to Corel tech support.
    Initially, Corel team sent a series of useless replies with the recommendations that we all know already: reset Corel Painter, update the drivers, blah blah. Then, finally this came from them:
    "Thank you for contacting Corel Technical Support. My name is Austin and I have been assigned to your ticket.
    After reviewing the facts before me, it has been found that the problem being reported is already known to us and has been reported to our Engineering department for review and action. This case will be elevated to the Engineering team to have action against it.
    Any replies or further communications, will come from me, once the Engineering team has provided a solution."
    So, this is a known bug to Corel's tech team, and they're working on it. At lease we know it's not about our setup and config.
    I think Surface Pro 7 is doing pressure sensitivity different from prev. versions, and Corel needs to release a patch to adapt it.
  4. tampopo
    Thank you for the update, it's good to know that Corel is working on it. Hope we can have a new and working patch soon.
  5. tampopo
    I think Corel is not care about Microsoft Surface Pro user! The pen pressure problem is still not fixed even on the new Corel Painter 2021. Very disappointed with this company.
  6. Bronsky
    8,611
    5,934
    Corel is a shell of its former self. I am a wrodperfect user and, at one time, actually used the Corel office suite. I moved to Office like every other human on the planet. Corel has done next to nothing to continue the development of its software.
  7. Marty
    3,682
    3,833
    Not sure if credit should go to Corel, but since they acquired Parallels, there have been some promising advancements for Pencil support (through Sidecar) in Windows:
    I will say that despite the slight stroke delay shown, it is still impressive under emulation, as Painter is one heavy drawing app. And it's nice to see the little bit of influence from Corel has made the Parallels team pay attention to the artist niche. :)
    Also @0:58, you can see the pen performance without the bulk of the Painter engine, damn if that's not faster than some drawing apps running on Windows natively!
    Sometimes you wonder why you even bother running a Windows machine at all... :p
    Bronsky likes this.
  8. tampopo
    That's @#!Q!%
    Running on an emulation system on iPad is better than running on Surface Pro 7?
    It's Microsoft or Corel's problem? Can Microsoft fix the problem if Corel not willing to do it??
